Author Topic: Ford Transit 2.5 Injection Pump on ALH  (Read 29539 times)
January 25, 2014, 07:10:06 am
« on: January 25, 2014, 07:10:06 am »
Has anyone run one?  A friend of mine sent me this pic of an engine he purchased.  He didn't see it run but the specs look good.  11mm plunger, the 20mm mainshaft rotates the correct direction, the sprocket offset is correct and the snout mounting hole is the same as the ALH.  The accelerator lever rotates the opposite direction of the VW mechanical pumps, but the ALH has the pump mounted far enough away from the engine that it wouldn't be an issue.
Reply #1January 25, 2014, 08:11:21 am
Re:
« Reply #1 on: January 25, 2014, 08:11:21 am »
Can't say I've seen one on a VW in any of the research I did looking for my pump. Someone will need to guinea pig!
Reply #2January 25, 2014, 09:37:49 am
Re: Ford Transit 2.5 Injection Pump on ALH
« Reply #2 on: January 25, 2014, 09:37:49 am »
I think the UK guy getting rover pumps over here has done some experimenting. He will not join this place though
Reply #3January 28, 2014, 09:04:45 am
wisconsinjohnson
  • 26
« Reply #3 on: January 28, 2014, 09:04:45 am »
I just talked to owner, you may have your guinea pig.  Checking it out tomorrow, sounds like no one has tried to start it.
Reply #4January 28, 2014, 03:43:06 pm
Re:
« Reply #4 on: January 28, 2014, 03:43:06 pm »
Sweet! Keep us posted. More options for mtdi!
Reply #5January 30, 2014, 08:56:28 pm
Sillycaddy
  • 20
« Reply #5 on: January 30, 2014, 08:56:28 pm »
Did you pick it up? I noticed the CL ad was taken down.
Reply #6January 31, 2014, 06:22:45 am
rbremiller
  • 69
« Reply #6 on: January 31, 2014, 06:22:45 am »
In a quick ebay search for this pump, I found 6 different pump#'s to choose from.
Ford Transit 2.5 Diesel   0460414146
Transit 2.5DI pump:   0 460 414 052
 Ford Transit 2.5 DI Bosch: 0460414153
Ford Transit FT 150 2.5 DI Bosch: 0460414152
FORD TRANSIT 2,5DI 51KW Motor:4FB 0460414123
FORD Transit IV und V 2.5 DI 56 KW 76 PS 0460414119
They appear to have the same specs/internals as a Rover pump; DI, 11mm and 4000rpm gov. Throttle levers are reversed. They are very plentiful and cheap.
'91 180k Audi 80Q mTDI DD AHU, K14, LT pump,
http://www.motorgeek.com/viewtopic.php?t=45645
'99 Jetta TDI 204k '02 engine, RC3+E, 11mm IP, .216, Racepipe, 2.5''SS exhaust, PD Lift pump,  Boostvalve, PanzerPlate, boost gauge, MAF delete.
'89 Audi 80Q ...waiting
'85 BMW R80
Reply #7January 31, 2014, 05:00:42 pm
snakemaster
  • 405
« Reply #7 on: January 31, 2014, 05:00:42 pm »
i have done a few .its very close to the LR pump , i lift the lid and snap of the steel part that restriks the control lever , so it gets more travel , sort of a LDA but for a non turbo , its a bit like a 1.9 td eco pump but a 2.5di one , the LDA parts dont fit in the lda looking thing on the ford transit pump .
Reply #8February 01, 2014, 03:48:31 pm
« Reply #8 on: February 01, 2014, 03:48:31 pm »
Thanks for the info, Snakemaster.  I didn't realize that it didn't have a functional LDA.  Bummer.
Reply #9June 18, 2019, 08:29:06 am
Dino
  • 44
« Reply #9 on: June 18, 2019, 08:29:06 am »
Hello.
That's the 0 460 414 052 pump.
REPLACING PARTS:
ORDER NUMBER    DESIGNATION    CODE    POSITION    QUANTITY
2 460 283 001    SHAFT SEALING RING    2460283001    3    1
1 467 030 308    SUPPLY PUMP    1467030308    7    1
1 467 030 303    SUPPLY PUMP    1467030303    7    1
1 460 134 317    SUPPORT RING    1460134317    9    1
1 463 429 300    TORX FLAT-HEAD SCREW    1463429300    10    2
1 466 100 390    DRIVE SHAFT    1466100390    12    1
1 460 023 302    WOODRUFF KEY    1460023302    13    1
1 460 056 302    BUFFER    1460056302    15    2
1 466 317 301    TOOTHED GEAR    1466317301    16    1
2 460 102 001    SLIDING DISK    2460102001    17    1
1 460 232 327    ROLLER RING    1460232327    20    1
1 463 100 307    BEARING PIN    1463100307    21    4
2 460 300 005    ROLLER    2460300005    22    4
2 460 120 013    FRICTION WASHER    2460120013    23    4
1 463 103 315    ADJUSTING PIN    1463103315    24    1
1 463 120 359    RETAINING PIN    1463120359    25    1
1 461 310 300    RETAINING BRACKET    1461310300    26    1
1 460 140 334    CROSS DISK    1460140334    27    1
1 466 110 619    CAM PLATE    1466110619    29    1
2 460 223 001    SEAL RING    2460223001    30    1
1 463 104 469    TIMING-DEVICE PISTON    1463104469    31    1
1 463 218 312    SLIDING PIECE    1463218312    32    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    33    2
1 464 619 734    COMPRESSION SPRING,   36,30 MM    1464619734    34    1
1 464 619 628    COMPRESSION SPRING,   36,50 MM    1464619628    34    1
1 464 619 619    COMPRESSION SPRING,   36,70 MM    1464619619    34    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    35    1
2 460 223 001    SEAL RING    2460223001    36    1
1 465 530 301    CLOSING COVER    1465530301    37    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    38    2
1 461 074 312    COVER PLATE    1461074312    39    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    40    2
1 468 334 487    HYDRAULIC HEAD    1468334487    50    1
2 460 210 012    O-RING    2460210012    51    1
   SELECTION GROUP SHIM       52    1
1 460 105 305    GASKET    1460105305    54    4
   FITTING       58    4
1 463 414 312    TORX FILLISTER SCREW    1463414312    60    2
1 460 210 008    O-RING    1460210008    66    1
1 467 134 815    HYDRAULIC STOP    1467134815    67    1
1 463 161 835    PART LOAD GOVERNOR    1463161835    68    1
1 200 101 640    SHIM    1200101640    69    1
1 461 900 496    CONTROL LEVER    1461900496    72    1
1 463 315 310    FLANGE NUT    1463315310    75    1
   ADJUSTING SCREW       88    1
1 461 015 302    GASKET    1461015302    92    1
1 461 907 810    FULCRUM LEVER    1461907810    95    1
2 916 012 017    PLAIN WASHER,   DIN 433 - 10,5-160 HV    2916012017    103    1
1 463 452 313    SLOTTED SHOULDER SCREW    1463452313    104    2
1 460 105 307    GASKET    1460105307    105    2
1 464 613 611    COMPRESSION SPRING    1464613611    106    2
1 463 300 304    HEXAGON NUT    1463300304    107    1
1 463 590 311    GOVERNOR SHAFT    1463590311    108    1
1 460 210 313    O-RING    1460210313    109    1
1 461 030 343    SHIM PLATE,   0,95 MM    1461030343    110    1
   SELECTION GROUP SUPPORTING DISK       111    1
1 466 317 319    FLYWEIGHT ASSEMBLY    1466317319    112    1
1 460 100 370    SHIM RING    1460100370    114    1
1 460 422 305    SLIDING SLEEVE    1460422305    115    1
1 461 290 301    LOCKING PLATE    1461290301    116    1
1 463 203 907    SELECTION GROUP PLUG    1463203907    117    1
2 910 142 207    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x35-8.8    2910142207    123    4
1 460 210 349    O-RING    1460210349    129    1
1 463 461 306    SCREW PLUG    1463461306    130    1
1 460 105 306    FLAT SEAL RING    1460105306    131    1
1 463 453 306    BLEEDER SCREW    1463453306    132    1
1 460 225 081    O-RING    1460225081    133    1
1 460 225 082    O-RING    1460225082    134    1
1 460 362 419    CONTROL VALVE    1460362419    135    1
1 463 456 358    HOLLOW BOLT    1463456358    136    1
1 460 591 315    PROTECTIVE CAP    1460591315    140    1
2 410 508 006    PROTECTIVE CAP    2410508006    141    1
2 464 633 002    COMPRESSION SPRING    2464633002    200    1
1 461 314 301    DISTANCE PIECE    1461314301    202    1
1 463 300 316    HEXAGON NUT    1463300316    206    1
2 916 699 137    SPRING LOCK WASHER,   DIN 128 - A14-FSt    2916699137    207    1
1 464 651 452    COILED SPRING    1464651452    220    1
1 467 230 360    CONTROL UNIT    1467230360    235    1
1 463 414 305    TORX FILLISTER SCREW    1463414305    237    2
0 330 001 040    PUSHING ELECTROMAGNET    0330001040    240    1
1 464 477 302    BLADE TERMINAL    1464477302    242    1
1 463 314 306    FLANGE NUT    1463314306    243    1
1 460 105 312    FLAT SEAL RING    1460105312    251    1
2 910 142 203    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x25-8.8    2910142203    254    2
1 466 434 309    COUPLING HALF    1466434309    270    1
2 916 699 132    SPRING LOCK WASHER,   DIN 128 - A6-FSt    2916699132    275    1
2 910 142 195    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x14-8.8    2910142195    276    2
2 460 223 001    SEAL RING    2460223001    277    1
2 410 508 006    PROTECTIVE CAP    2410508006    285    1
1 461 900 514    CONTROL LEVER    1461900514    289    1
1 463 433 310    WASHER-AND-SCREW ASSEMBLY    1463433310    292    1
1 463 218 303    INTERMEDIATE PIECE    1463218303    294    1
1 460 342 311    INTERMEDIATE PIECE    1460342311    295    1
1 463 412 301    CHEESE HEAD SCREW    1463412301    296    1
1 463 305 305    CLAMPING PIECE    1463305305    297    1
1 463 450 308    BREAK-OFF SCREW    1463450308    307    2
1 460 522 328    SPRING SEAT    1460522328    325    1
1 460 522 304    SPRING SEAT    1460522304    329    1
2 911 222 700    HOLLOW BOLT    2911222700    353    1
2 911 222 700    HOLLOW BOLT    2911222700    357    1
1 460 105 313    FLAT SEAL RING    1460105313    358    2
1 460 105 313    FLAT SEAL RING    1460105313    364    2
1 460 793 350    CONNECTING PIPE    1460793350    365    1
1 460 101 620    SHIM    1460101620    380    1
1 465 530 857    FITTING COVER    1465530857    381    1
1 461 933 344    CONTROL LEVER    1461933344    382    1
1 461 933 341    CONTROL LEVER    1461933341    382    1
1 461 331 331    STOP BRACKET    1461331331    383    1
1 464 651 433    COILED SPRING    1464651433    384    1
2 916 699 132    SPRING LOCK WASHER,   DIN 128 - A6-FSt    2916699132    385    1
2 915 012 007    HEXAGON NUT,   ISO 4032 - M6-8-A    2915012007    386    1
1 461 901 483    CONTROL LEVER    1461901483    388    1
1 460 300 318    SPACER BUSHING    1460300318    389    1
2 912 732 197    WASHER-AND-SCREW ASSEMBLY    2912732197    391    1
1 460 210 322    O-RING    1460210322    392    1
1 463 414 306    LOCKING SCREW    1463414306    393    1
1 461 331 325    INTERMEDIATE PLATE    1461331325    394    1
2 423 450 002    BREAK-OFF SCREW    2423450002    418    2
2 915 012 007    HEXAGON NUT,   ISO 4032 - M6-8-A    2915012007    422    1
1 461 329 339    MOUNTING BRACKET    1461329339    492    1
1 463 126 333    SPHERICAL BOLT    1463126333    496    1
1 463 314 309    FLANGE NUT    1463314309    499    1
1 463 315 307    HEXAGON NUT    1463315307    580    2
1 465 130 862    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130862    800    1
1 467 010 054    PARTS SET FLYWEIGHT    1467010054    805    1
1 460 591 313    SEALING CAP,   RED    1460591313    808    1
2 420 580 005    SEALING CAP,   RED    2420580005    809    1
Unfortunately I can't do any attachment to make it appears as on the web page I found it.
I'll look for the other pumps.
0 460 414 119
REPLACING PARTS:
1 460 232 328    ROLLER RING    1460232328    20    1
2 463 100 002    BEARING PIN    2463100002    21    4
1 463 103 316    ADJUSTING PIN    1463103316    24    1
1 460 140 334    CROSS DISK    1 460 140 334    27    1
1 466 110 653    CAM PLATE    1466110653    29    1
1 463 104 508    TIMING-DEVICE PISTON    1463104508    31    1
1 460 144 302    SHIM RING    1460144302    33    1
1 464 618 934    COMPRESSION SPRING    1464618934    34    1
1 460 100 178    PLAIN WASHER    1460100178    35    1
1 465 530 901    CLOSING COVER    1465530901    37    1
1 461 074 330    COVER PLATE    1461074330    39    1
2 463 414 001    TORX FILLISTER SCREW    2463414001    40    2
1 468 334 859    HYDRAULIC HEAD    1468334859    50    1
2 463 370 021    FITTING    2463370021    58    4
1 460 210 008    O-RING    1460210008    66    2
1 467 135 997    HYDRAULIC STOP    1467135997    67    1
1 463 162 081    PART LOAD GOVERNOR    1463162081    68    1
1 461 900 613    CONTROL LEVER    1461900613    72    1
1 461 907 803    FULCRUM LEVER    1461907803    95    1
1 460 422 324    SLIDING SLEEVE    1460422324    115    1
1 460 508 309    SEALING CAP    1460508309    116    1
2 463 461 002    SCREW PLUG    2463461002    130    1
2 463 461 001    BLEEDER SCREW    2463461001    132    1
1 460 362 456    CONTROL VALVE    1460362456    135    1
1 463 456 360    HOLLOW BOLT    1463456360    136    1
1 461 314 322    DISTANCE PIECE    1461314322    202    1
1 461 021 621    SUPPORT PLATE    1461021621    235    1
1 466 434 324    COUPLING HALF    1466434324    270    1
1 461 900 616    CONTROL LEVER    1461900616    289    1
1 461 900 615    CONTROL LEVER    1461900615    289    1
1 463 433 313    WASHER-AND-SCREW ASSEMBLY    1463433313    292    1
1 460 100 893    PLAIN WASHER    1460100893    346    1
1 460 793 379    CONNECTING PIPE    1460793379    365    1
1 461 335 346    CONTROL LEVER    1461335346    388    1
1 460 100 199    SPACER RING    1460100199    389    1
2 912 732 197    WASHER-AND-SCREW ASSEMBLY    2912732197    391    2
1 463 300 320    HEXAGON NUT    1463300320    422    1
   SELECTION GROUP SHIM       452    3
1 464 616 340    COMPRESSION SPRING    1464616340    453    1
1 463 219 304    CONTROL SPOOL    1463219304    455    1
1 460 505 308    CLOSURE CAP    1460505308    471    1
2 916 012 013    PLAIN WASHER, DIN 433 - 6,4-160 HV    2916012013    546    1
1 467 010 062    PARTS SET COVER PLATE    1467010062    700    1
1 465 134 990    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465134990    800    1
0 460 414 123
REPLACING PARTS:
1 467 135 996    HYDRAULIC STOP    1467135996    67    1
1 461 903 310    CONTROL LEVER    1461903310    388    1
1 464 616 998    COMPRESSION SPRING    1464616998    453    1
1 464 616 955    COMPRESSION SPRING    1464616955    453    1
1 464 616 344    COMPRESSION SPRING    1464616344    453    1
I found them on danmax.ee
« Last Edit: June 18, 2019, 08:49:36 am by Dino »
Reply #10June 18, 2019, 08:50:44 am
Dino
  • 44
« Reply #10 on: June 18, 2019, 08:50:44 am »
0 460 414 146
REPLACING PARTS:
1 461 074 328    SEALING PLATE    1461074328    30    1
1 463 104 667    TIMING-DEVICE PISTON    1463104667    31    1
1 461 038 319    SEALING PLATE    1461038319    36    1
2 461 038 019    COVER PLATE    2461038019    39    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    40    4
1 463 414 361    MICROENCAPSULATED SCREW,      MICO    1463414361    60    2
1 467 135 999    HYDRAULIC STOP    1467135999    67    1
F 002 D11 460    GOVERNOR SHAFT,      MICO    F002D11460    108    1
1 463 414 362    MICROENCAPSULATED SCREW,      MICO    1463414362    237    2
0 330 001 041    PUSHING ELECTROMAGNET    0330001041    240    1
2 410 508 006    PROTECTIVE CAP    2410508006    285    2
F 002 D11 455    HOLLOW BOLT,      MICO    F002D11455    353    1
F 002 D11 455    HOLLOW BOLT,      MICO    F002D11455    357    1
1 465 134 967    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465134967    800    1
0 460 414 152
REPLACING PARTS:
0 281 005 025    SOLENOID-VALVE CONTROL UN    0281005025    184    1
1 464 651 460    COILED SPRING    1464651460    220    1
1 461 021 889    SUPPORT PLATE    1461021889    235    1
2 910 142 203    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x25-8.8    2910142203    254    3
1 467 010 556    PARTS SET THEFT PROTECTION    1467010556    825    1
0 460 414 153
REPLACING PARTS:
1 466 110 639    CAM PLATE    1466110639    29    1
1 464 616 963    COMPRESSION SPRING    1464616963    453    1
News of the engine and the injection pump?
Unfortunately the engine picture is missing and I don't know the pump code.
I hope there isn't any piece of mistake about datas and that they can be useful.
The application list is missing,there's a long VE pump list on that site and it seems that those pump are capable of 4000rpms as it was already said.
« Last Edit: June 18, 2019, 09:17:39 am by Dino »
Reply #11June 18, 2019, 10:25:28 am
Dino
  • 44
« Reply #11 on: June 18, 2019, 10:25:28 am »
Hello.
There are other Ford Transit injection pumps.
Mark    Type    Part number    Applications    Photo    Engine
bosch    VE    0460404005 VE R 14/1    Ford Transit 100/190 46 kw       York
bosch    VE    0460414073 VE R 366    Ford Transit 2.5D 52 kw        4 AB, 4 CA     Enquiries
bosch    VE    0460414083 VE R 415    Ford Transit 2.5 DI 59 kw        4 DA
bosch    VE    0460414108 VE R 567    Ford Transit 2.5 D 56 kw       4 HA, 4 HB, 4 FA, 4 FC
bosch    VE    0460414113 VE R 567/1    Ford Transit 2.5 D 51 kw        4 FA, 4 FB, 4 FC
bosch    VE    0460414119 VE R 624    Ford Transit, Tourneo 51-56 kw        4 FB, 4HB, 4HC …
bosch    VE    0460414146 VE R 686/3    Ford Transit 2.5 D 56 kw        4 HB, 4 HC KAT
bosch    VE    0460414150 VE R 624/4    Ford Transit 2.5 D 56 kw        4 FA, 4 FB, 4 FC 4 HB, 4 HC
I think there is something strange,Tourneo. What is it?
The pumps must be for old vans.
Maybe the first of the list is for an IDI engine.
By looking at the engine power I can't understand if they are all N/A engine or the turbos add just some hp.
The parts list of all those pump is avaiable too.
0 460 414 073
REPLACING PARTS:
   FITTING       58    4
1 467 134 823    HYDRAULIC STOP    1467134823    67    1
1 463 162 063    PART LOAD GOVERNOR    1463162063    68    1
1 461 900 564    CONTROL LEVER    1461900564    72    1
1 461 900 566    CONTROL LEVER    1461900566    289    1
1 463 433 310    WASHER-AND-SCREW ASSEMBLY    1463433310    292    2
1 461 933 363    CONTROL LEVER    1461933363    382    1
1 461 933 362    CONTROL LEVER    1461933362    382    1
1 461 903 304    CONTROL LEVER    1461903304    388    1
1 460 200 339    SPACER RING    1460200339    389    2
0 460 414 083
REPLACING PARTS:
1 468 334 580    HYDRAULIC HEAD    1468334580    50    1
1 467 134 842    HYDRAULIC STOP    1467134842    67    1
1 461 900 639    CONTROL LEVER    1461900639    72    1
1 461 907 808    FULCRUM LEVER    1461907808    95    1
1 464 616 956    COMPRESSION SPRING    1464616956    453    1
« Last Edit: June 21, 2019, 10:03:17 am by Dino »
Reply #12June 21, 2019, 10:13:03 am
Dino
  • 44
« Reply #12 on: June 21, 2019, 10:13:03 am »
Hello.
0 460 414 108
REPLACING PARTS:
1 463 414 312    TORX FILLISTER SCREW    1463414312    60    1
1 467 134 840    HYDRAULIC STOP    1467134840    67    1
1 467 230 404    CONTROL UNIT    1467230404    235    1
1 463 414 305    TORX FILLISTER SCREW    1463414305    237    3
1 460 300 312    SPACER BUSHING    1460300312    248    1
1 460 591 318    HOOD    1460591318    720    1
0 460 414 113
REPLACING PARTS:
1 467 134 843    HYDRAULIC STOP    1467134843    67    1
0 460 414 150
REPLACING PARTS:
F 002 D11 347    PUSHING ELECTROMAGNET    F002D11347    240    1
0460414073    VE4/11F2000R366
0460414083    VE4/11F2000R415
0460414108    VE4/11F2000R567
0460414113    VE4/11F2000R567-1
0460414119    VE4/11F2000R624
0460414123    VE4/11F2000R624-1
0460414146    VE4/11F2000R686-3
0460414150    VE4/11F2000R624-4
0460414152    VE4/11F2000R624-6
0460414153    VE4/11F2000R624-7
Reply #13August 03, 2019, 10:03:51 am
Dino
  • 44
« Reply #13 on: August 03, 2019, 10:03:51 am »
Hello.
Another Ford Transit pump.
0460414085    VE4/11F2000R415-1
REPLACING PARTS:
1 460 140 337    CROSS DISK    1460140337    27    1
1 461 335 348    CONTROL LEVER    1461335348    388    1
1 463 126 333    SPHERICAL BOLT    1463126333    500    1
1 463 314 309    FLANGE NUT    1463314309    503    1
There's another Ford injection pump with the same camplate,it's used on Ford Ranger 2.5. Is it a rebagded Mazda pick up?
That's the same camplate used for Croma 0460414096 and 0460414125 injection pumps.
According the 2009-2010 catalogue the same camplate was used for an industrial engine too. The list isn't complete,for exemple Croma pumps are missing.
On web there are other 2000rpms pumps but the application list is missing,they can be for Transit,Land Rover or other engines.
I thought that I can add the pumps with the same number after R and the"-".
Camplate 1 466 110 619:0460414083,0460414085,0460414200(Ford Ranger),0460424082,0460424091.
Other pumps with the same number after the R.
0460414089    VE4/11F2000R415-2
0460414107    VE4/11F2000R415-3
0460414138    VE4/11F2000R624-2
0460414139    VE4/11F2000R624-3
0460414151    VE4/11F2000R624-5
0460414208    VE4/11F2000R686-4
0 460 414 089
REPLACING PARTS:
1 467 134 835    HYDRAULIC STOP    1467134835    67    1
It seems that there is the ADA on those pumps.
« Last Edit: August 03, 2019, 11:17:48 am by Dino »
Reply #14August 03, 2019, 11:22:11 am
Dino
  • 44
« Reply #14 on: August 03, 2019, 11:22:11 am »
0 460 414 107
REPLACING PARTS:
1 467 134 830    HYDRAULIC STOP    1467134830    67    1
1 464 616 334    COMPRESSION SPRING    1464616334    453    1
1 463 315 307    HEXAGON NUT    1463315307    580    1
0 460 414 138
REPLACING PARTS:
0 460 414 139
REPLACING PARTS:
