Author Topic: Attn Libby v6 mtdi  (Read 5595 times)
January 25, 2014, 06:27:17 am
bbob203
  • 1789
Attn Libby v6 mtdi
« on: January 25, 2014, 06:27:17 am »
I think someone needs to put one of these in a vanagon.
http://forums.tdiclub.com/showthread.php?t=404751
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1January 25, 2014, 06:49:06 am
Re: Attn Libby v6 mtdi
« Reply #1 on: January 25, 2014, 06:49:06 am »
I've thought about it.  It would fit, but the stock vanagon trans would not hold up to the torque.  Going mid-engine would be a lot of work and the options for upgrading the trans (spins backwards because trans is in front of engine) are limited and expensive.  All done, I'm sure it would be an excellent powerplant.
Reply #2January 25, 2014, 08:36:59 am
  • 1739
« Reply #2 on: January 25, 2014, 08:36:59 am »
I thought the heads on those engines were garbage. Sure they can be replaced/rebuilt, but who wants to do that every couple of years.
Reply #3January 27, 2014, 04:04:18 am
CdnVWJunkie
  • 309
« Reply #3 on: January 27, 2014, 04:04:18 am »
I'm pretty sure it's the cams that are suspect.
Reply #4January 30, 2014, 02:37:32 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #4 on: January 30, 2014, 02:37:32 am »
been a loooong time since I posted here, but came back because I just bought an '03 Allroad with the 2.5 v6 TDI and wanted to see if there were any projects going on here :-)
I don;t think theres any real substance to the 'soft cams' myth. My car has 220,000km on it and it runs very sweetly and has heaps of power - but it also has a perfect service history since new, serviced every 15,000km or less at the audi dealer.
From what I've read, the real problems arose with these engines when on the 'variable service interval' regime, when you could go up to 30,000km. But, if anyones read the owners manual, you must use the correct oil if on this service interval (505.01 - NOT just 505) which most mechanics would take no notice of.... infact IME theres also about a 30% price premium for the 505.01 oil over one that complies just with 505.
Anyhoo, the V5 TDI is a beauty, smooth as silk and considering the Allroad is 1800kg without passengers and with quattro, 7.5l/100km that I got off the first tank I'd say its a really good engine!
'91 Golf Cabrio 1.9TD
Reply #5February 02, 2014, 06:33:54 am
CrazyAndy
  • 739
« Reply #5 on: February 02, 2014, 06:33:54 am »
Maybe not a Vanagon, but now that the gears are turning in my head, what about a dasher/quantum setup?
Reply #6February 02, 2014, 07:18:29 am
bbob203
  • 1789
« Reply #6 on: February 02, 2014, 07:18:29 am »
***ing a. QSW v6 mtdi.
03 Jetta wagon TDi
Reply #7February 02, 2014, 10:41:40 am
bbob203
  • 1789
03 Jetta wagon TDi
