Author Topic: VE pump leaking from LDA  (Read 3936 times)
December 24, 2013, 02:13:47 am
phaetonv10
  • 83
« on: December 24, 2013, 02:13:47 am »
Hi guys
my pump has started to leak. the leak is on the side of the LDA, from the atmosphere bleed valve i suppose. its the small valve next to the adjustment screw, the valve that has a rubber cover on it.
what do i do to fix it?????
THE LEMON
1.6 GTD, FMIC, ARP Studs, Brembo brakes, Power Clutch, ibiza tdi twin fan setup, Racing Seats, 40 mm all aluminium radiator, audiophile music.
Reply #1December 24, 2013, 02:46:25 am
anto
Re: VE pump leaking from LDA
« Reply #1 on: December 24, 2013, 02:46:25 am »
There is a little seal inside the lda where the lda pin is. Thats what is leaking, need to fix that seal.
Reply #2December 25, 2013, 01:01:27 pm
« Reply #2 on: December 25, 2013, 01:01:27 pm »
You have to take the top off your pump and then take the whole top part (LDA) apart. It's not the easiest seal to get to. Make sure you know what you are doing before you take the top off. There are lots of settings that you can easily mess up if you don't record them all first!
Reply #3December 25, 2013, 01:03:43 pm
bbob203
  • 1789
« Reply #3 on: December 25, 2013, 01:03:43 pm »
I thonk libby made a how to once upon a time.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4December 25, 2013, 01:42:25 pm
RustyCaddy
  • 395
« Reply #4 on: December 25, 2013, 01:42:25 pm »
Reply #5December 25, 2013, 02:00:28 pm
phaetonv10
  • 83
Re:
« Reply #5 on: December 25, 2013, 02:00:28 pm »
Thanks a lot guys. I ll get it done by a diesel pump specialist.
Cheers.
Sent from my Q10 using Tapatalk 4 Beta
THE LEMON
Reply #6December 26, 2013, 07:45:32 am
anto
« Reply #6 on: December 26, 2013, 07:45:32 am »
If you've got the pump with ball bearings instead of screwheads then it can be a pain in the arse to do that seal.
Reply #7December 26, 2013, 09:21:24 am
« Reply #7 on: December 26, 2013, 09:21:24 am »
The ball bearings are no big deal.
Reply #8December 26, 2013, 11:16:48 am
8v-of-fury!
« Reply #8 on: December 26, 2013, 11:16:48 am »
They're not a big deal, but they are a pain compared to nice screws.. lol
Reply #9December 26, 2013, 05:09:31 pm
« Reply #9 on: December 26, 2013, 05:09:31 pm »
!!!!!!!!!!!!!!!!!!!!  :D  :D  :D
JEREMY IS BACK!!!!!
Reply #10December 27, 2013, 12:54:12 pm
anto
« Reply #10 on: December 27, 2013, 12:54:12 pm »
My biggest concern with the ball bearings is that they dont seal when reinserting them?
Reply #11December 27, 2013, 12:58:08 pm
« Reply #11 on: December 27, 2013, 12:58:08 pm »
I've r+r'd many of them and never had one leak.  If you are concerned, then it is also fairly easy to tap the holes to NPT and add the socket head plugs.
« Last Edit: December 27, 2013, 04:31:31 pm by libbydiesel »
