Author Topic: K03/K04 hybrid on a eurovan w/ rocketchip stage 3, bigger nozzles etc  (Read 3030 times)
November 27, 2013, 10:00:31 am
bbob203
  • 1789
A guy I'm helping with a eurovan ahu build bought a new k03/k04 hybrid. He is gonna have a properly ported head, bigger nozzles(unsure of size ATM), Rocketchip stage 3 tune, .5mm over asv pistons, some sort of front mount, pd150 intake. I really think he is going to have egt problems on this thing. Tons of intake and no exhaust flow. Keep in mind this is a Weekender not a regular eurovan. Libby, Jockey and Lucas I'm looking at you guys. I told him a k14 or t2 would be better. He said maybe a vnt17 might be an option for him at a later date. I really think he needs to decide now before the motor is in.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1November 27, 2013, 10:16:00 am
  • 7834
Re: K03/K04 hybrid on a eurovan w/ rocketchip stage 3, bigger nozzles etc
« Reply #1 on: November 27, 2013, 10:16:00 am »
which k03/k04 hybrid?
Reply #2November 27, 2013, 10:20:19 am
bbob203
  • 1789
03 Jetta wagon TDi
Reply #3November 27, 2013, 10:27:57 am
  • 7834
« Reply #3 on: November 27, 2013, 10:27:57 am »
sadly it doesn't say what it is for A/R, wheel size, trim or a map. I was looking to see what it actually was capable of. I would say he is in need of a bigger turbo for a rocketship stage 3, but I am not searching for a map to know for sure. Also I couldn't find a chart to say what for HP stage 3 will be making, so if he is only around 140hp it maybe fine.
Reply #4November 27, 2013, 07:17:42 pm
snakemaster
  • 405
« Reply #4 on: November 27, 2013, 07:17:42 pm »
when i get time i am going to take out my 1z and fit a afn with the vnt 15 bigger nozzles , LT intercooler and 3" exhaust from turbo back , MTDI , with stand alone E vnt controler , and hopping for 145HP ish all in my eurotrashvan
Reply #5December 02, 2013, 11:40:13 am
CrazyAndy
  • 739
« Reply #5 on: December 02, 2013, 11:40:13 am »
I agree with Lucas on this one, I think he is under-turboed for a stage 3 tune.  If he was getting only a stage 1.5-2 I might be a little more at ease, but 3 is a lot of fuel for even a K03/K04.  A VNT 17 or  even 17/22 sounds better for this application since it has more exhaust flow.  I'd also ask about how big his front mount is, because something as massive as a eurobox is a lot of weight to thor around especially at low speeds where airflow across the IC might not be ideal.  Has he considered air-to-water?
Reply #6December 02, 2013, 12:42:15 pm
  • 5065
« Reply #6 on: December 02, 2013, 12:42:15 pm »
do you know what turbos this hybrid is made from?
Reply #7December 02, 2013, 12:51:35 pm
bbob203
  • 1789
« Reply #7 on: December 02, 2013, 12:51:35 pm »
ko3 from an ahu hot unsure of cold. He has decided on a vnt 17 or an s7.
03 Jetta wagon TDi
Reply #8December 02, 2013, 02:02:42 pm
CrazyAndy
  • 739
« Reply #8 on: December 02, 2013, 02:02:42 pm »
VNT 17 is most likely the best candidate; still have the option for the 22 cold side if in the future he decides to go bigger, since 17/22 does more boost than an s7.  If he wants to just do one turbo, though, the s7 might be a good one to choose since it spins up like 17 but handles a little more boost than a stock 17. Might go with the stage 3 tune, but IDK since I don't know the nozzle size.
Fixmyvw.com
