Author Topic: K14 boost pot screw  (Read 2314 times)
November 26, 2013, 08:11:21 pm
Gizmoman
  • 1301
K14 boost pot screw
« on: November 26, 2013, 08:11:21 pm »
If a guy were to back out the screw at the end of the boost canister on a K14, wouldn't that allow boost to come on sooner? Or is it entirely dependent on RPMs?
Reply #1November 27, 2013, 05:32:37 am
Re: K14 boost pot screw
« Reply #1 on: November 27, 2013, 05:32:37 am »
that would allow the valve to open more, but has nothing to do with when the boost comes on. Boost is dependent on heat and rpm
Reply #2November 27, 2013, 05:48:28 am
bbob203
  • 1789
« Reply #2 on: November 27, 2013, 05:48:28 am »
Opening that more will also keep the boost from spiking when using a ball and spring mbc.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3November 27, 2013, 06:22:46 am
Gizmoman
  • 1301
« Reply #3 on: November 27, 2013, 06:22:46 am »
Thanks. I do have a ball and spring MBC. Can you elaborate on what "spiking" is?
Reply #4November 27, 2013, 06:30:15 am
« Reply #4 on: November 27, 2013, 06:30:15 am »
MBC set to 10 psi, it will "spike" to say 14psi and then come down to 10psi where it is set. I personally haven't seen the spiking resolved with the valve able to open more, but I think that is the function of my MBC not being reactive enough. I have seen it reduce a little bit of "creep" which is MBC set at 10psi and it slowly just keeps creeping until it levels off at whatever psi it chooses, like 18psi, even though it is set for 10psi.
