General Information
General
Fittings for custom TDi/AAZ oil drain.
Topic: Fittings for custom TDi/AAZ oil drain. (Read 4133 times)
November 18, 2013, 04:09:11 am
bbob203
November 18, 2013, 04:09:11 am »
These look to be the same size as the factory fittings. Posting the think for myself and for others.
http://www.ebay.com/itm/Turbo-Water-Pipe-M16x1-5mm-Garrett-T3-TB03-SAAB-VOLVO-Nissan-R31-R33-1-2-Hose-/380768712813?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a795786d&vxp=mtr
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
November 18, 2013, 05:08:16 am
Re: Fittings for custom TDi/AAZ oil drain.
November 18, 2013, 05:08:16 am »
wonder if that is the same as the IP banjo?
Round 2
November 18, 2013, 05:45:59 am
November 18, 2013, 05:45:59 am »
Quote from: theman53 on November 18, 2013, 05:08:16 am
IP banjo is the same as the oil feed line on AAZ/AHU/1Z engines.
November 20, 2013, 05:37:08 am
stewardc
November 20, 2013, 05:37:08 am »
Why use a banjo at all? I converted mine to AN fittings. MUCH nicer.
November 20, 2013, 05:55:55 am
bbob203
November 20, 2013, 05:55:55 am »
I was thinking this may work for the DRAIN banjo fitting on the back of the block but i think its to small.
03 Jetta wagon TDi
November 20, 2013, 06:54:23 am
stewardc
November 20, 2013, 06:54:23 am »
Once again, why use a banjo on the drain??? Use an AN hose.
November 25, 2013, 04:01:54 am
stewardc
November 25, 2013, 04:01:54 am »
Here are the parts you need.
General Information
General
