Author Topic: TDI glowplug solution from TDi Club courtesy of Vince Waldon  (Read 6881 times)
November 15, 2013, 04:50:45 am
bbob203
  • 1789
« on: November 15, 2013, 04:50:45 am »
Since vince doesn't post here much anymore I figured i'd spread this since a lot folks here avoid TDi Club.
Quote from: Vince Waldon;4350936
It will also take an 8-32 machine screw die, which might be a little easier to find hardware for in some locations:
In terms of the factory harness...there was a model change somewhere in the 2001-2002 timeframe where VW switched from 2-wire harnesses to 4-wire harnesses, in part to allow plug-specific diagnostics.  The old two-wire harness has been NLA for some time now, so anyone that repairs a 2-wire engine generally has to splice in the available 4-wire harness.
Or delete it entirely and run one's own wires...as heavy-duty as one's OCD requires.   :-)
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1November 15, 2013, 06:12:33 am
Re: TDI glowplug solution from TDi Club courtesy of Vince Waldon
« Reply #1 on: November 15, 2013, 06:12:33 am »
^^^^ Great idea
I'm definitely doing that.  :D
Reply #2November 16, 2013, 03:00:25 am
homerj1
  • 433
« Reply #2 on: November 16, 2013, 03:00:25 am »
Did this on my 1.6, combined with separate fuses for each glow plug and the results have been great.
Reply #3November 16, 2013, 04:34:09 am
« Reply #3 on: November 16, 2013, 04:34:09 am »
The main difference is the 1.6 glow plugs are already threaded.
Reply #4November 16, 2013, 04:37:05 am
bbob203
  • 1789
« Reply #4 on: November 16, 2013, 04:37:05 am »
I tried that on my mk2 but had issues with the fuse block being junk and just went to a single fuse coming off a starter solenoid. Going to wire my TDi glowplugs in series to a single 50 amp large maxi fuse to a solenoid. The TDi glow plugs are so easy to pull that I don't think individual is necessary except on the later ALH where they are wired individually from the harness. A 4mmx.7mm die also works to cut threads on the posts of the glow plugs as well.
03 Jetta wagon TDi
Reply #5November 16, 2013, 05:39:35 am
« Reply #5 on: November 16, 2013, 05:39:35 am »
You could just use bullet connectors.
Reply #6November 16, 2013, 05:46:42 am
bbob203
  • 1789
« Reply #6 on: November 16, 2013, 05:46:42 am »
I have messed around with those but I don't like them any of the ones I've found found deform when you put them on and take them off again and don't seem to keep a good connection. I cant find any in 12-10 ga wire. Cutting some threads will be a minimal task and a die only costs 4 dollars and will presumably last a lifetime.
03 Jetta wagon TDi
Reply #7November 16, 2013, 06:53:38 am
« Reply #7 on: November 16, 2013, 06:53:38 am »
just rember your shifter when you goto cut threads... seen idi plugs breakj taking the nut off like your shifter did..
Reply #8November 16, 2013, 06:57:57 am
« Reply #8 on: November 16, 2013, 06:57:57 am »
The Ford IDI IH late 6.9/7.3 were bullet style connectors. How often are you removing your glow plug harness? lol
Reply #9November 16, 2013, 10:52:39 am
« Reply #9 on: November 16, 2013, 10:52:39 am »
Those trucks have a huge issue with the connectors becoming loose, corroded, falling off and then the truck doesn't start. If you want one of those trucks I bet you could find one cheap right now that's it's getting colder usually with the phrase "ran great a month ago, can't get it to start anymore."
Reply #10November 16, 2013, 12:31:24 pm
Re:
« Reply #10 on: November 16, 2013, 12:31:24 pm »
Over on TDIClub you will find tons of posts from people with corroded / failed glow plug harnesses. That's why Vince posted that over there in the first place. The factory push on connection is less than reliable.
Reply #11November 16, 2013, 06:04:37 pm
« Reply #11 on: November 16, 2013, 06:04:37 pm »
WAY less than reliable, in my experience, hence good ole fashioned threads and nuts  rather than press-ons  :) :)
Reply #12November 16, 2013, 06:16:04 pm
bbob203
  • 1789
« Reply #12 on: November 16, 2013, 06:16:04 pm »
Well i threaded a "stale" glowplug i had laying around no issue with dislocating the post its shank can be gripped with a pair of pliers to cut the threads. Debating on spade terminals or ring terminals.
03 Jetta wagon TDi
Reply #13November 16, 2013, 06:20:42 pm
« Reply #13 on: November 16, 2013, 06:20:42 pm »
ring better then spade... and you figured out plier trick... just no break like shifter sir... you now know to support it.. :D
