Author Topic: What are these parts?  (Read 3710 times)
March 15, 2006, 06:05:07 pm
zagarus
  • 619
« on: March 15, 2006, 06:05:07 pm »
Just starting to get myself familiar with everything on my 1.6TD, sooo, what is this?
And this?
I will post more pictures of other things i have questions about.  Just let me know if i should be puttign them somewhere else or if this is okay here, i really want to start working on the engine this summer and well i wanna know what everything is and how they work. thanks.
Reply #1March 15, 2006, 08:02:04 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
« Reply #1 on: March 15, 2006, 08:02:04 pm »
Top one's the crankcase valve. I haven't looked at my TD one in a while, but if it's giving you problems (oil in your intake), you can do WingNut's CCV v 3.0 from tdiclub.
The other one looks like your Wastegate, but I'm not sure. Again, the TD has been sitting in the street for 6 months now. I hardly remember what anything looks like.
Reply #2March 15, 2006, 08:25:45 pm
zagarus
  • 619
« Reply #2 on: March 15, 2006, 08:25:45 pm »
so that bottom one is th wastegate, sweet, is there anything i can do to it?
Reply #3March 15, 2006, 08:29:58 pm
sethyboy85
  • 284
« Reply #3 on: March 15, 2006, 08:29:58 pm »
bottom is a BOV... it leaks boost at 10-12psi so you don't get too carried away with power.
you can tighten it up or cap it so it doesn't leak.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #4March 15, 2006, 08:59:34 pm
zagarus
  • 619
« Reply #4 on: March 15, 2006, 08:59:34 pm »
by doing so would maintain teh boost correct.  i think ill wait till next week or so when i get a boost gauge.
Reply #5March 15, 2006, 09:27:25 pm
dubCanuck1
  • 279
« Reply #5 on: March 15, 2006, 09:27:25 pm »
There's some wastegate and BOV mods that you can do to get more air. It's like the "bible" article here. I just can't find it.
You'll want to increase your fueling at the same time if you're dumping more air into the system, so I'd look at doing the governor'ectomy mod to retard the level at which the fuel starts cutting off. If you start pushing silly power later, look into the GTD injectors and an upgraded pump. Knowing you're on a student budget, I'm saying you probably want to put those off. The first mods are pretty much free. The latter ones will cost you over $1000.
Lastly, start looking for an intercooler. The TDs don't have them stock, so your turbo blows hot air right back into the intake manifold. Cooling that pressurized air will make your car run better.
Reply #6March 15, 2006, 10:19:39 pm
zagarus
  • 619
« Reply #6 on: March 15, 2006, 10:19:39 pm »
ya im getting my car all planned out, i already increased the fuel a little, (not the gov mod) but enough that i notice more power, so now i just wanna up the boost a bit to add to the fuel, this sumemr will be intercooler.
Reply #7March 15, 2006, 11:34:34 pm
Cheesetoast
  • 285
« Reply #7 on: March 15, 2006, 11:34:34 pm »
Reply #8March 23, 2006, 08:09:06 am
okron1k
  • 111
« Reply #8 on: March 23, 2006, 08:09:06 am »
Quote from: "dubCanuck1"
any luck on finding that "bible"
