S-PAutomotive.com
Author Topic: AAZ rotary vacuum pump seal  (Read 4566 times)
November 04, 2013, 01:44:17 am
Blue Haze
  • 49
    82 caddy w/AAZ 1.9 motor 5spd w/ A/C
« on: November 04, 2013, 01:44:17 am »
After reading some older posts I think the seal may be bad in my AAZ rotary pump.  I only can hold 5" vacuum at idle and it does not go up much when I rev up.  Oil pressure is low also. What is this seal --an actual  oil seal or an O ring.  Can some one furnish the size or part number.  Am I going to be able to find this at any parts store or special order from someone?   Are there rebuild kits for these pumps or just order a new one? I think Parts Place, Inc has them for $250.  I have the old diaphragm style for the 1.6 but I don't think they will interchange.
Reply #1November 04, 2013, 08:40:51 am
  • 1508
Re: AAZ rotary vacuum pump seal
« Reply #1 on: November 04, 2013, 08:40:51 am »
There is a seal at the bottom of the vac-pump that is not an o-ring. It sits in a groove inside the gear and seals against the oil-pump shaft.
#11 in the pic
I don't know if the seal is the same # as for a 1.6 .
Fixmyvw.com
