Author Topic: Cam sprockets.  (Read 7988 times)
November 03, 2013, 10:25:59 am
One_punchmachinegun
  • 261
Cam sprockets.
« on: November 03, 2013, 10:25:59 am »
Hey really quick question. I was doing my dad's TB(alh) and the cam sprocket cracked, so instead of pay 80 bucks I checked if a 1.6 spocket matched up and they are identical. Do you think this is alright to do
的f anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1November 03, 2013, 10:41:55 am
One_punchmachinegun
  • 261
Re: Re: Cam sprockets.
« Reply #1 on: November 03, 2013, 10:41:55 am »
Identical other than the inner part of the sprocket. Same tooth count and size.
Reply #2November 04, 2013, 04:37:22 am
Re: Cam sprockets.
« Reply #2 on: November 04, 2013, 04:37:22 am »
tooth count is definitely the same, the taper/press fit should be the same, but i have never worked on an alh to be able to tell you it will work.
Reply #3November 04, 2013, 05:30:54 am
One_punchmachinegun
  • 261
« Reply #3 on: November 04, 2013, 05:30:54 am »
Yeah, I ended up just buying one. I will get all the measurements when I get the new one. I really think that they are the same. The ALH one design sucks, it's much weaker. It cracked because I didn't use the VW specific tool and I used my own sprocket puller. But I could only get on the outside of it and when I started to apply pressure the outer sprocket wheel came right off leaving the rest of the sprocket on the cam. I've never had issues with the older 1.6.
Reply #4November 04, 2013, 05:36:21 am
bbob203
  • 1789
Re: Cam sprockets.
« Reply #4 on: November 04, 2013, 05:36:21 am »
I agree weal design also doesn't help when people crank them down to 60ftlbs to.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #5November 04, 2013, 06:10:05 am
Re: Cam sprockets.
« Reply #5 on: November 04, 2013, 06:10:05 am »
Yeah people totally overtorque them, probably scared of the press fit.  I always just tapped them off with a hammer, a quick swift knock and they come right off.
Reply #6November 04, 2013, 06:15:49 am
Re: Cam sprockets.
« Reply #6 on: November 04, 2013, 06:15:49 am »
If there was only a way to drill a hole in the plastic timing cover back side so you could do it just like a 1.6
Reply #7November 04, 2013, 06:36:58 am
Re: Cam sprockets.
« Reply #7 on: November 04, 2013, 06:36:58 am »
Is that sarcasm?  There is specific spot cast into the plastic backing plate for drilling a hole and using a punch on the rim of the sprocket.  I have never had any issue getting them off that way without damage.  I make sure the mating surfaces do not have any oil residue by cleaning using brake-clean and then torque to 45 ft-lbs.  I know of more than one cam that slipped from the factory without ever having been loosened.  That leads me to believe the factory torque spec is too low.
Reply #8November 04, 2013, 08:40:23 am
Re: Cam sprockets.
« Reply #8 on: November 04, 2013, 08:40:23 am »
hmm thanks for the tip, ive been doing the 33 or w/e it is.
Reply #9November 04, 2013, 08:43:27 am
bbob203
  • 1789
Re: Cam sprockets.
« Reply #9 on: November 04, 2013, 08:43:27 am »
I do 33 + a little extra
03 Jetta wagon TDi
Reply #10November 04, 2013, 10:19:59 am
One_punchmachinegun
  • 261
« Reply #10 on: November 04, 2013, 10:19:59 am »
Yeah same here. About 40-45lbs.
Yeah the thing was so on there I had to remove the cam to get it off after it had broke. Even then it wasnt easy. If I had to guess it was torque to 100. It was solid.
Reply #11November 04, 2013, 11:33:20 am
Re: Cam sprockets.
« Reply #11 on: November 04, 2013, 11:33:20 am »
id ask the dr diesel guy who made cams... if his cam fit a aaz and a tdi.. id say same..
yep plastic has spot to drill... hammer/punch.. no need for puller till pd that ive seen
Reply #12November 04, 2013, 01:04:40 pm
One_punchmachinegun
  • 261
« Reply #12 on: November 04, 2013, 01:04:40 pm »
Good advise right there.. thanks
Reply #13November 04, 2013, 04:14:03 pm
Re: Cam sprockets.
« Reply #13 on: November 04, 2013, 04:14:03 pm »
Yeah it was a bit sarcastic. I mean if you don't own a set of bits that will drill through the plastic you probably shouldn't attempt the TB job.
Reply #14November 04, 2013, 05:47:15 pm
« Reply #14 on: November 04, 2013, 05:47:15 pm »
Remember we had someone who was smacking the transmission end of the cam with a hammer trying to make the sprocket pop off the other end? Always good to make sure things are spelled out for the next guy...
