Author Topic: ME1.6na crank bolt question  (Read 9710 times)
Reply #15October 17, 2013, 10:03:46 am
Re: ME1.6na crank bolt question
« Reply #15 on: October 17, 2013, 10:03:46 am »
As I mentioned in the other thread, the keyway is equally stressed by holding the sprocket or the crank.  You are not reducing the stress on the keyway by holding the crank, you are just making your life more difficult.  Easy proof is that the sprocket holder works on the cam for loosening and torquing.
Reply #16October 17, 2013, 09:39:16 pm
EcoTX
  • 113
« Reply #16 on: October 17, 2013, 09:39:16 pm »
Oil pan off
Block of wood or two between the crank and block where the rod throw is so it binds works wonders for me
Reply #17October 17, 2013, 09:53:36 pm
« Reply #17 on: October 17, 2013, 09:53:36 pm »
That works especially well for turning a 5 minute project into an hour and getting little bits of wood in your crankcase.
Reply #18October 17, 2013, 10:34:04 pm
air-cooled or diesel
« Reply #18 on: October 17, 2013, 10:34:04 pm »
and perhaps lifting car some, there by negating some of the torque applied. if your on jacks (and/or stands) you may lift car off platform some, and press crank at same time.
Reply #19October 18, 2013, 01:23:24 am
Toby
  • 728
« Reply #19 on: October 18, 2013, 01:23:24 am »
You guys have way to much time on your hands.The key is not to carry the load, it is only for alignment purposes. It is the friction between the nose of the crank and the sprocket. (Piss poor design) That is the reason for such a great amount of torque on the bolt. If the key shears, it is because the bolt was not tight enough. If you are worried about the bolt coming loose, just put some red Locktite on it. This is almost never a problem until someone removes the bolt. It is exceedingly important the the sprocket go back on COMPLETELY clean and oil free or you run the risk it slipping.
If you think about it, the forces on the sprocket are not that great, so this should not be much of an issue if done correctly. You just can't do it in a sandbox with filthy hands and no way hold the crank, and guestimating what the correct torque is..
Reply #20October 18, 2013, 05:23:57 am
« Reply #20 on: October 18, 2013, 05:23:57 am »
If you think about it, the crank sprocket is being torqued severely between the intermittent crank pulses and the loads/momentum of the cam, IM shaft, IP, balancer, waterpump, AC compressor, PS pump and alternator. So much so, that VW went to the clutched alt-pulley to reduce the slamming effect.
I will never subscribe to the theory that the clamping action of the crank bolt is the primary force holding the sprocket position.
The bolt ensures the key doesn't move, the key being the primary means of holding the sprocket in position. A real key rarely wallows out, the jakey key on the later 1.6 was a very poor idea.
Reply #21October 18, 2013, 09:57:41 am
« Reply #21 on: October 18, 2013, 09:57:41 am »
Red Locktite on the crank bolt is a TERRIBLE IDEA, almost as bad as super-gluing on your underwear.  WRT guestimating the torque, Toby, weren't you the one suggesting to install the crank sprocket bolt with an impact not too long ago...
Reply #22October 18, 2013, 10:49:14 am
« Reply #22 on: October 18, 2013, 10:49:14 am »
thats for damn sure they're already difficult enough to get off.
Reply #23October 18, 2013, 11:06:37 am
« Reply #23 on: October 18, 2013, 11:06:37 am »
The crank bolts or your small clothes?
Reply #24October 18, 2013, 12:45:16 pm
Re:
« Reply #24 on: October 18, 2013, 12:45:16 pm »
Both probably
Reply #25October 18, 2013, 06:29:08 pm
« Reply #25 on: October 18, 2013, 06:29:08 pm »
Technically it is the friction, not the clamping.
Reply #26October 18, 2013, 07:06:08 pm
mzak88
  • 31
« Reply #26 on: October 18, 2013, 07:06:08 pm »
I don't mind using red... Millwright thing. If problem getting off I apply heat carefully to BOLT, let sit for a while. it will come loose, no problem.
97 IDI Jetta, O2A CTN,0.658 5th, 1.6 boost pin, TDI IC, 2.0 brakes, some tuning.
Reply #27October 18, 2013, 07:20:43 pm
bbob203
  • 1789
« Reply #27 on: October 18, 2013, 07:20:43 pm »
I've never had any problem loosening them quite frankly it always seemed easier than people made it out to be. Only time I've ever done it though the engines where out of the car.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #28October 18, 2013, 07:39:51 pm
« Reply #28 on: October 18, 2013, 07:39:51 pm »
Ha ha.  Yeah if you know it's there.  Ever sold a car to someone?  That poor sucker broke his flywheel ring gear trying to get that bolt loose after you stuck red on it for no good reason...
« Last Edit: October 18, 2013, 07:41:50 pm by libbydiesel »
Reply #29October 18, 2013, 10:17:52 pm
« Reply #29 on: October 18, 2013, 10:17:52 pm »
Rubbish.
There ain't sufficient surface area to hold a gnat's nutz. The underside of the bolt is about the same size and it turns with a measly 150ftlb.
The IP key is just for alignment, it has a taper shaft with 4x the surface area of the crank nose and 1/8 the inertial load. Likewise with the camshaft, and it proves the IP doesn't need the key for holding in position.
