Author Topic: Fan speed 1-3 doesn't work speed 4 works only..  (Read 9692 times)
October 10, 2013, 06:18:23 pm
bbob203
  • 1789
« on: October 10, 2013, 06:18:23 pm »
Got a new fan switch to replace the old one that melted and i still have one of the problems i had before 1-3 doesn't work and the blower resistor was replaced a month ago. ???
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1October 10, 2013, 06:40:52 pm
Re:
« Reply #1 on: October 10, 2013, 06:40:52 pm »
If high works and the rest don't that points to the month old resistor or the wiring to it
Reply #2October 10, 2013, 06:59:46 pm
Re: Fan speed 1-3 doesn't work speed 4 works only..
« Reply #2 on: October 10, 2013, 06:59:46 pm »
ohhh yea text...
melted switch.... better check wires/plugs/terminals....................
Reply #3October 12, 2013, 03:47:02 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #3 on: October 12, 2013, 03:47:02 pm »
Probably the bearings in the blower are seizing,
Reply #4October 14, 2013, 05:58:17 pm
bbob203
  • 1789
« Reply #4 on: October 14, 2013, 05:58:17 pm »
Replaced the control unit and 1 2 3 still don't work and don't light up the test light but 4 does. Blower feels ok but I don't know what a new one feels like so im going to go to the local vw shop and compare the feel of a new one to mine. Im bad with electrical work.. suggestions? CRS gave me some pointer but still open to more ideas.
03 Jetta wagon TDi
Reply #5October 15, 2013, 05:38:21 am
« Reply #5 on: October 15, 2013, 05:38:21 am »
ohm meter is what you gotta use next.. gotta test control and control to resistor wires...
Reply #6October 15, 2013, 06:45:34 am
Re: Re: Re:
« Reply #6 on: October 15, 2013, 06:45:34 am »
Reply #7October 15, 2013, 09:15:36 am
bbob203
  • 1789
« Reply #7 on: October 15, 2013, 09:15:36 am »
I'm thinking sluggish blower blew the thermal fuse on the new resistor.
03 Jetta wagon TDi
Reply #8October 15, 2013, 02:32:39 pm
bbob203
  • 1789
« Reply #8 on: October 15, 2013, 02:32:39 pm »
Replaced the thermal fuse on the resistor and went a picked up a good used blower for 45 bucks all is well and everything works!
03 Jetta wagon TDi
Reply #9October 15, 2013, 03:42:03 pm
« Reply #9 on: October 15, 2013, 03:42:03 pm »
Sweet.
FWIW, New blowers don't cost much, and I've gotten mixed results with used blowers... like a year, tops.
Reply #10October 15, 2013, 04:23:26 pm
bbob203
  • 1789
« Reply #10 on: October 15, 2013, 04:23:26 pm »
Well when on u.e. and cc's gotta cut the costs..
03 Jetta wagon TDi
Reply #11October 15, 2013, 05:53:29 pm
« Reply #11 on: October 15, 2013, 05:53:29 pm »
10-4
Reply #12October 15, 2013, 06:03:58 pm
bbob203
  • 1789
« Reply #12 on: October 15, 2013, 06:03:58 pm »
I agree though on that count normally i go new but this one looked like it was in good shape and said it came from a 96 and wasn't dusty at all. I figure mine had to be the original from 92 so this one ought to last 4 years if it is the original one from 96. The thermo fuse seems to be what goes on the resistor due to th fan drawing to much when it wears out.
03 Jetta wagon TDi
Reply #13October 25, 2013, 02:23:24 pm
« Reply #13 on: October 25, 2013, 02:23:24 pm »
Sweet.
AC blowers are cheap..
non-ac blowers are unobtanium, and spendy..
they also take a special resistor pack..
i spent almost $100 on those 2 parts alone..
Reply #14October 30, 2013, 12:40:17 pm
thegimpster
  • 243
    • VDubShirts.com Awesome VW themed shirts with attitude
« Reply #14 on: October 30, 2013, 12:40:17 pm »
I still have a complete non ac setup at the shop. I sold the last one for 300. they are expensive as ***.
Check out www.vdubshirts.com for cool VW themed shirts with attitude.
