Author Topic: Driveshafts and Hubs, Educate Me!  (Read 2965 times)
October 01, 2013, 02:56:17 pm
Henk
  • 111
« on: October 01, 2013, 02:56:17 pm »
Okay here's my issue:
At the moment have an Audi TDi longitudinal 'box and equal length driveshafts all as standard from the Audi 80.
I don't want 4x108 hubs as it's a terrible size, and making my own is out of the question.
I'm led to believe Golf MK2 used the same driveshaft splines, at approx 34 spline, 26mm OD, but again 4x100 isn't much better, and as it is i'll need driveshaft spacers due to to track width increase.
So, what cars have equal length driveshafts, would quattro/syncro etc rear driveshafts be strong enough? (Target is a well modified inline 5 TDi)
Or passat, they had a FWD engine the wrong way around in the B5's i think?
Can't really use 2 of the same side or the bolt will unscrew itself i assume
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #1October 01, 2013, 03:25:58 pm
Re: Driveshafts and Hubs, Educate Me!
« Reply #1 on: October 01, 2013, 03:25:58 pm »
can use same side... but i  think the drivesaft dimeters for spines and such different... going to have to play with parts...
Reply #2October 01, 2013, 04:00:33 pm
« Reply #2 on: October 01, 2013, 04:00:33 pm »
WE did a car with a Porsche  944 transaxle, narrowed cradle,and two short side shafts to match the narrow car.
Reply #3October 02, 2013, 01:24:20 pm
Henk
  • 111
« Reply #3 on: October 02, 2013, 01:24:20 pm »
hmm well of the few driveshafts i've had they splines have all been the same so far, but surely there's a reason why you get a left hand and a right hand thread in them?
Did you use off the shelf driveshafts for that then?
Don't want anything custom or joining driveshafts incase i go and break one, would want to be able to buy another at any local parts place
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #4October 02, 2013, 01:51:12 pm
« Reply #4 on: October 02, 2013, 01:51:12 pm »
no left hand/right hand that i can say ive ever seen on vw/audi cvs...
Reply #5October 20, 2013, 04:08:09 pm
« Reply #5 on: October 20, 2013, 04:08:09 pm »
Early CGT and 4K used 4x100 bolt pattern..
just use those spindles..
S-PAutomotive.com
