Author Topic: MK2 TD items (most local pickup only in Portland, OR)  (Read 3897 times)
September 24, 2013, 06:39:20 am
vic_vr6
  • 12
« on: September 24, 2013, 06:39:20 am »
MK2 diesel fuel tank with sender and water separator box with wiring pig tails.
nice item for a mk2 tdi swap. the actual diesel tank has a larger opening in the filler neck so you can use fast fill diesel pumps at truck stops and what not. the gasser filler neck is smaller.
$25 local pickup only.
MK2 diesel Accessory brackets.
This is the setup you need for running A/C on a diesel. Also includes diesel alternator with "W" terminal. a little rusty but should clean up nicely. I have the diesel AC lines and compressor but those are condition unknown.
$20 - i might ship this but it will be heavy and costly.
« Last Edit: October 01, 2013, 06:22:09 am by vic_vr6 »
Reply #1September 24, 2013, 07:56:16 pm
billybobf
  • 318
Re: MK2 TD items (most local pickup only in Portland, OR)
« Reply #1 on: September 24, 2013, 07:56:16 pm »
if the trans is still available I might be interested in it.  Maybe if dale makes the run I could convince him to bring it to me :D although I might be going up there car shopping
Reply #2September 24, 2013, 08:04:51 pm
bbob203
  • 1789
« Reply #2 on: September 24, 2013, 08:04:51 pm »
it costs 75 to ship and 020. ALt shouldnt cost more than 25 or 30 bucks in the us.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3September 24, 2013, 08:43:16 pm
audilvr
« Reply #3 on: September 24, 2013, 08:43:16 pm »
i'd buy the cast downpipe piece (upper) if the shipping was reasonable. can't find good ones around here.
Reply #4September 26, 2013, 06:58:47 am
« Reply #4 on: September 26, 2013, 06:58:47 am »
The cast downpipe fits in a medium flat rate box for $11.30 (if you use the USPS online site).  I am sure because I just sold one on ebay a couple days ago.  You can even order the flat rate box online and your post man will deliver it to you.  You can also schedule pickup by your postman for the following day.  You've gotta love modern convenience.
