Author Topic: Someone with a 1Z/AHU and Vag-Com want to help me out?  (Read 3128 times)
September 18, 2013, 08:05:46 pm
« on: September 18, 2013, 08:05:46 pm »
I am inquiring to know how many lb/min of air a stock 1Z/AHU flows so that I can properly pick a turbo charger for it.
Reply #1September 19, 2013, 06:45:09 pm
410
  • 581
Re: Someone with a 1Z/AHU and Vag-Com want to help me out?
« Reply #1 on: September 19, 2013, 06:45:09 pm »
The maf on the ahu maxed out pretty early and won't give you the number you're looking for.  The maf on the ALH can read quite a bit higher.  I checked my ALH on the drive home tonight and the maf peaked at 20.4 lb/min.  It peaked around 4000 rpm but it was a little hard watching everything all at the same time so 4000 is a rough estimate.  It will be interesting to see if the number will increase with the next few mods I have.  I have a pd intake, a better SMIC, and a colt stage 2 cam sitting on the shelf.  All mods that should improve breathing.
Reply #2September 19, 2013, 07:52:04 pm
« Reply #2 on: September 19, 2013, 07:52:04 pm »
I`d be super appreciative if you wouldn't mind documenting that for me ;)
20.4 at 4000 is quite near the estimate I have on the turbo calculator.. so it would seem that at 5750 (theoretical red-line, as I wouldn`t go higher..) moves like 33 lb/min.
