Author Topic: Loud rattle after modding the plunger 1.6TD  (Read 9632 times)
Reply #30September 19, 2013, 04:59:23 pm
Blocksmith
  • 261
    Wrench Lurker
Re: Loud rattle after modding the plunger 1.6TD
« Reply #30 on: September 19, 2013, 04:59:23 pm »
Having donned my flame suit...IIRC reading that Giles removes most or all of the dynamic advance in a lot of his pumps; would that help?
I was under the impression that one of the critical things that makes Giles pumps so incredible is that he puts in more dynamic advance. He says to time them to a more retarded static position, IIRC from my reading, precisely because he's got the dynamic advance built in.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #31September 19, 2013, 05:25:25 pm
« Reply #31 on: September 19, 2013, 05:25:25 pm »
No I think it is the opposite, he builds a ton of dynamic advance into the pump. He also says a timing spec of .90-.95mm as the base timing is not needed as much because of it. Giles pretty much deletes the governor, if that is what you were thinking.
Reply #32September 19, 2013, 08:41:38 pm
RustyCaddy
  • 395
« Reply #32 on: September 19, 2013, 08:41:38 pm »
More, not less, dynamic advance does make sense and given Giles timing recommendations more understandable...thanks
