Author Topic: Caddy locking gas cap or door?  (Read 5495 times)
September 13, 2013, 08:08:58 am
92EcoDiesel Jetta
« on: September 13, 2013, 08:08:58 am »
Has anyone found a locking fuel cap for a Caddy?
 If not, anyone figure out a way to lock the door?
Reply #1September 13, 2013, 12:30:06 pm
Re: Caddy locking gas cap or door?
« Reply #1 on: September 13, 2013, 12:30:06 pm »
Reply #2September 15, 2013, 10:13:29 am
« Reply #2 on: September 15, 2013, 10:13:29 am »
My Jettas have lockers
PN: 191 201 553
EDIT:
Seems AutohausAZ sells the locker for Diesel same as the Audi part linked above.
« Last Edit: September 15, 2013, 10:16:47 am by TylerDurden »
Reply #3September 15, 2013, 10:49:26 am
« Reply #3 on: September 15, 2013, 10:49:26 am »
my findings back in 94..... stant made one... was nla then...
jewlery store type of lock for case.... put hole in door.. cut slot in opening by door for tab to lock into...
no go look at locks for what i mean.. will not spoon feed the thought... but simple if you go look at locks like such..
Reply #4September 15, 2013, 10:56:40 am
92EcoDiesel Jetta
« Reply #4 on: September 15, 2013, 10:56:40 am »
 Jetta cap won't fit caddy. Jetta screw in. Caddy 2 prong bayonet 1/4 turn. I'll make a deadbolt for door with a choke cable unlock.
Reply #5September 15, 2013, 11:02:55 am
« Reply #5 on: September 15, 2013, 11:02:55 am »
How about a simple cabinet lock that you install on the door?  Or do you want it to be inside cab operated?
Reply #6September 15, 2013, 11:11:36 am
92EcoDiesel Jetta
« Reply #6 on: September 15, 2013, 11:11:36 am »
I prefer a no key (to lose) solution.
Reply #7September 15, 2013, 02:53:29 pm
« Reply #7 on: September 15, 2013, 02:53:29 pm »
look at b3/b4 gas door.... rig it... if it screws you know where to pull rod... else honda....
Reply #8September 15, 2013, 06:30:15 pm
RustyCaddy
  • 395
« Reply #8 on: September 15, 2013, 06:30:15 pm »
Might try Stant again...bought on from them about 5 years ago so may be they go in and out of nla
Reply #9September 15, 2013, 06:42:48 pm
bbob203
  • 1789
« Reply #9 on: September 15, 2013, 06:42:48 pm »
Have you had someone steal your fuel?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #10September 15, 2013, 07:17:56 pm
« Reply #10 on: September 15, 2013, 07:17:56 pm »
Reply #11September 15, 2013, 08:24:28 pm
92EcoDiesel Jetta
« Reply #11 on: September 15, 2013, 08:24:28 pm »
Can you post your locking Stant p/n? The p/n's I found was unclear whether it's locking or not and with no pics.
Reply #12September 15, 2013, 08:26:49 pm
92EcoDiesel Jetta
« Reply #12 on: September 15, 2013, 08:26:49 pm »
No, but with a lock, no one can else can take from it or add to it.
Reply #13September 15, 2013, 08:30:45 pm
92EcoDiesel Jetta
« Reply #13 on: September 15, 2013, 08:30:45 pm »
IIRC, the vanagon is a 1/4 turn cap...
http://www.gowesty.com/ec_view_details.php?id=2242&category_id=224&category_parent_id=
So is a MK 1 Jetta locking cap, which has the same bayonet 1/4 turn twist but did not fit the caddy because the o.d. was too big.
Reply #14September 16, 2013, 02:52:43 am
damac
  • 531
« Reply #14 on: September 16, 2013, 02:52:43 am »
My 83 gti gasser cap fits onto my 82 diesel truck?
But niether has a lock so no clue if that makes a difference.
1985 turbo diesel jetta
