Author Topic: injector heat shields stuck  (Read 3614 times)
September 09, 2013, 10:59:16 pm
Kazuki
  • 61
« on: September 09, 2013, 10:59:16 pm »
as it says my heat Shields are stuck as i need to replace them  and i cant seem to remove them ive soaked them in pblaster over night and they still don't want to come out ive tried heating them and still no luck any tips ? im loosening my mind
Reply #1September 10, 2013, 12:22:40 am
Re: injector heat shields stuck
« Reply #1 on: September 10, 2013, 12:22:40 am »
do not put oil in them holes...... bad idea.. you gotta get it out now.....
i tap a long tapered punch into the middle of them... but do some depth searching first.. too long and you poke hole into coolent passagwe... then give a wiggle and out the come on the punch...
Reply #2September 10, 2013, 01:21:53 am
« Reply #2 on: September 10, 2013, 01:21:53 am »
Bike spoke or coathanger bent in tight hook usually serves me well.
Reply #3September 10, 2013, 03:14:12 am
Toby
  • 728
« Reply #3 on: September 10, 2013, 03:14:12 am »
Ahh..... hit the starter?
PB Blaster is not going to help. The injectors were not sealing and they are carboned up, not rusted. I like to start with a punch that is about 1/2 the diameter of the injector nozzle. Give it a good whack with a heavy hammer. You are trying to break up the carbon under them and deform the heat shield in hopes of breaking the carbon under it.  Next I use a tapered punch that will just fit into the hole in the heat shield. Again, give it a good whack which should stick it in the heat shield. Then wiggle the punch in hopes of freeing the heat shield up. If worse comes to worse I heat the heat shield with an acetylene torch to red hot and let it cool a bit and try working it out. Some are a *** but I have never seen one that I could not get out. Don't worry about hurting the head with the torch. (Unless you are trying to use a huge rosebud, of course.) A welding tip is all you need. Be careful with the torch if the motor is full of PB Blaster though. That stuff is as volatile as white gas.
Reply #4September 10, 2013, 03:52:38 am
« Reply #4 on: September 10, 2013, 03:52:38 am »
Don't hit the heat shields too hard. You'll can bugger up the head.
Sometimes all you need to do is crank it over and they will blow out. I usually take a small punch and do a bunch of small taps around the outside of the heat shield. If that doesn't knock it loose I stick the punch in the hole of the heat shield and rock it back and forth. That pretty much always works.
Unless you put a lot of PB blaster in there, I'd just crank it over and blow it over. If there is a lot I'd just turn it slowly and let it run out the injector hole. I doubt you put that much in there though
Reply #5September 10, 2013, 09:43:54 pm
Kazuki
  • 61
« Reply #5 on: September 10, 2013, 09:43:54 pm »
got them out with a easy out was a PITA just hope nothing fell on the piston i vacuumed it out a couple times im going to crank it over by hand and hope shes clean other wise the heads coming off .
Reply #6September 13, 2013, 06:12:19 pm
« Reply #6 on: September 13, 2013, 06:12:19 pm »
You had to get the shields out with an easy out???
Wow, I have never seen them stuck so bad.
Reply #7September 13, 2013, 07:16:01 pm
« Reply #7 on: September 13, 2013, 07:16:01 pm »
I've had a couple of severely stuck ones.  I just ran a propane torch on them until they started to smoke and then they came out without any effort.
Reply #8September 16, 2013, 02:07:41 pm
Kazuki
  • 61
« Reply #8 on: September 16, 2013, 02:07:41 pm »
yeah it was pretty bad
