Author Topic: Replace Nozzles  (Read 3282 times)
September 09, 2013, 11:40:02 am
rodpaslow
  • 670
Replace Nozzles
« on: September 09, 2013, 11:40:02 am »
I've looked in search and no dice!   In TDI newbie 101, is the nozzle replacement exactly like a IDI?  Shims are needed to adjust pressure?  where does one buy shims if needed.
I already have a pressure tester, just wanting to know if I can change these nozzles myself.  (.216 nozzles)
Reply #1September 09, 2013, 01:25:35 pm
thegimpster
  • 243
    • VDubShirts.com Awesome VW themed shirts with attitude
Re: Replace Nozzles
« Reply #1 on: September 09, 2013, 01:25:35 pm »
Here is a link on how to do it http://pics2.tdiclub.com/pdf/injector_install_howto.pdf
i was going to do it myself on my caddy with the new nozzles, but a place localy only charged me $15 each to clean, set the pressure, and in stall the nozzles. For that i'll gladly spend $60 and save me the time
Check out www.vdubshirts.com for cool VW themed shirts with attitude.
Reply #2September 09, 2013, 02:12:25 pm
homerj1
  • 433
Re: Replace Nozzles
« Reply #2 on: September 09, 2013, 02:12:25 pm »
I used the above link when I installed .205 nozzles into my AHU a few years ago. It is not really that hard to do. Best bang for the $$$ in my opinion.
Reply #3September 09, 2013, 07:39:16 pm
ToddA1
  • 434
Re: Replace Nozzles
« Reply #3 on: September 09, 2013, 07:39:16 pm »
TDI injectors are dual stage.  Most places don't have the equipment to check both stages, only the primary. In fact I know of only 2 places in the US that claim to be able to calibrate both stages.
Is it necessary to calibrate?  Well that can be a heated debate.
A nozzle swap is easy, if you just want to go that route. Unsure where to source the shims and I'm also unsure if IDI shims are the same.
-Todd
