Author Topic: Best coolant reservoir or swap?  (Read 3425 times)
September 04, 2013, 05:12:25 pm
jaed_43725
« on: September 04, 2013, 05:12:25 pm »
Is there a metal reservoir for the older style that someone makes? If not is there a swap to put on the ball style one, but nothing I have to do welding or such with? And lastly if the other 2 are a failure, what is the best plastic tank? I ask because my res decided to split on me. Thanks.
Reply #1September 04, 2013, 05:20:05 pm
Gizmoman
  • 1301
Re: Best coolant reservoir or swap?
« Reply #1 on: September 04, 2013, 05:20:05 pm »
Most local auto part places have crappy generic ones for around ten becks to get you by. Yo can even make something from a plastic jug if youre fairly handy - thy don't take any pressure - that is if your talking about the overflow tank.
Then you'll have time to do a craigslist search or someone who carries the stock one (if its still available).
Reply #2September 04, 2013, 05:57:45 pm
« Reply #2 on: September 04, 2013, 05:57:45 pm »
On a 85 the coolant tank definitely is pressurized. Why don't you just get a new one?
Reply #3September 04, 2013, 06:02:26 pm
« Reply #3 on: September 04, 2013, 06:02:26 pm »
171121407F
1H0121407A
Both of those are plastic and good IMHO for the MK2 style
171121407E
Same as the one but no coolant sensor. All have worked for me.
Reply #4September 04, 2013, 06:23:31 pm
jaed_43725
« Reply #4 on: September 04, 2013, 06:23:31 pm »
I am going to get a new one. I just don't want that junk stock style, unless its the ball. So does anyone know if there is a ball style that will fit on somehow? Or best yet a metal one?
Reply #5September 04, 2013, 06:28:14 pm
« Reply #5 on: September 04, 2013, 06:28:14 pm »
get oem, the generic ones are *** and dont last very long.
Reply #6September 04, 2013, 07:58:52 pm
« Reply #6 on: September 04, 2013, 07:58:52 pm »
I've run used good ones from junkyards with no problems.
My friend, on the other hand, has tried making pressurized coolant bottles out of aluminum and they don't last very long, they crack at the seams, and he is a certified welder. I think that metal fatigues and breaks after so many "cycles" of heating, expansion and cooling. I guess it makes sense when you consider that even low pressure gas cylinders are made out of like 1/4" steel.
Reply #7September 04, 2013, 10:39:29 pm
« Reply #7 on: September 04, 2013, 10:39:29 pm »
imo the older ones work better then ball...
Reply #8September 04, 2013, 11:25:02 pm
  • 2931
« Reply #8 on: September 04, 2013, 11:25:02 pm »
 If it's an old Jetta like the one in his sig it probably doesn't have the ball.
 Probably doesn't know they are available new, and cheap,.. $12.
  I'm happy with how thick the ones from autohausaz are.
« Last Edit: September 04, 2013, 11:27:09 pm by fatmobile »
Reply #9September 05, 2013, 01:45:25 am
damac
  • 531
« Reply #9 on: September 05, 2013, 01:45:25 am »
I have bought whatever http://www.autohausaz.com offers for the past 5 years.  Every chasis I have come across I blindly bought a new reservoir with coolant hoses, just like the one that comes on 85 jetta(not a ball), and I haven't had one problem yet?
1985 turbo diesel jetta
