Author Topic: 1.6TD parts  (Read 3528 times)
August 25, 2013, 06:49:31 am
1.6TD parts
« on: August 25, 2013, 06:49:31 am »
I will combine items to save on shipping. I have other parts not listed so feel free to ask. I also have duplicates of items. If you want an item that is not listed I will get you pictures of it before selling it to you.
Pictures are below:
Intake manifold (with bolts) $60 sold
Exhaust manifold (The studs for mounting the brace are there and could probably be used again but really they should be replaced. Regular bolts would do fine) $65 sold
T3 Turbo (with bolts) sold
Downpipe $35 sold
Intake elbow (with clamps) $5 sold
Intake boot (with clamps) $10
Air Box $25 SOLD
Oil filter flange $10 sold
Oil feed pipe $15 -  sold
Oil drain $40 - sold
Aftermarket, used oil pan (OEM used available, or new is also available) $30 sold
Valve cover with splash guard and breather tubes $10
Rear motor mount $5
Not pictured:
AAZ K03 turbo with boots and exhaust manifold $150
Turbo diesel pump - Came off a running car (blown headgasket and seized turbo so the car did not run well) $175
Stock oil cooler $5
Turbo Diesel lower downpipe $20
« Last Edit: September 02, 2013, 09:27:06 am by burn_your_money »
