TDI Engine -General Info
k14 reclocking
Topic: k14 reclocking (Read 3492 times)
August 25, 2013, 05:00:56 am
bbob203
k14 reclocking
August 25, 2013, 05:00:56 am »
I want to recroute my intercooler pipes so I can run an Eco airbox. Only way I can figure is if my compressor outlet points straight down and run the pipe on the frame like how it is on a mk4. I just want to know if reclocking is as simple as loosening and rotating it?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
August 25, 2013, 06:03:00 am
Re: k14 reclocking
August 25, 2013, 06:03:00 am »
time for vnt then... bottom mount.. else the engine mount in way...
August 25, 2013, 06:17:34 am
Re: k14 reclocking
August 25, 2013, 06:17:34 am »
Clocking the K14 intake scroll is as easy as loosening the clamp bolts on the perimeter of the scroll, rotating scroll to desired position and tightening the bolts back down.
August 25, 2013, 09:10:21 am
Re: k14 reclocking
August 25, 2013, 09:10:21 am »
but he forgetting rear engine mount a b3 has vs a mk4... no where for pipe to go... heck mk4 has that silly squish tube to make it fit.. that is not imo good flowing.. with bottom mount vnt.. may be able to use the factory vnt squish pipe and will clear the axle.. but to closk his top mount turbo on a b3.. no way with the rear mount..
August 25, 2013, 09:18:02 am
bbob203
Re: k14 reclocking
August 25, 2013, 09:18:02 am »
With the right bends/ angles and some fanagling it will work.
03 Jetta wagon TDi
k14 reclocking
