Author Topic: flywheel bolts n90206101  (Read 7044 times)
August 23, 2013, 05:54:02 am
dave friday
  • 122
« on: August 23, 2013, 05:54:02 am »
Hi All,are these bolts torque to yield [stretch] are they re-usable [with more blue locktite].
Ta.
1992 1600 td syncro camper
Reply #1August 23, 2013, 06:49:36 am
bbob203
  • 1789
Re: flywheel bolts n90206101
« Reply #1 on: August 23, 2013, 06:49:36 am »
blue loctite and your good. I've reused them several times no issues.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 23, 2013, 07:08:47 am
« Reply #2 on: August 23, 2013, 07:08:47 am »
If you are talking about the ones that are 12pt 9mm then yes, they are reusable.
Reply #3August 23, 2013, 08:29:33 am
dave friday
  • 122
« Reply #3 on: August 23, 2013, 08:29:33 am »
Thanks both,the bolts i'm talking about fix the flywheel to the crankshaft [hex head].
Reply #4August 23, 2013, 10:23:28 am
bbob203
  • 1789
« Reply #4 on: August 23, 2013, 10:23:28 am »
Some reuse those some don't... I do and have several times in various applications with no issues. Those need cleaned off and re loctited to seal the threads and protects clutch from oil.
03 Jetta wagon TDi
Reply #5August 23, 2013, 04:42:11 pm
« Reply #5 on: August 23, 2013, 04:42:11 pm »
Officially they are one time use.
Reply #6August 23, 2013, 09:58:32 pm
Rising
  • 385
Re: Re: flywheel bolts n90206101
« Reply #6 on: August 23, 2013, 09:58:32 pm »
I reused mine on my build cause I was pressed for time and I didn't have another week to wait for parts. Not available locally. Just cleaned the threads and blue loctited. Been 12000 miles and no issues yet. But its always in the back of my mind and it scares me a bit.
When I do the clutch I'll replace them. . . Just for peace of mind. Just my .02 :)
Sent from my ADR6400L using Tapatalk 2
'84 Rabbit Diesel- 1.6D Stock
Reply #7August 24, 2013, 03:30:26 am
bbob203
  • 1789
« Reply #7 on: August 24, 2013, 03:30:26 am »
Vw shop here been reusing them for 30 years. I went to buy new ones from them and he said I don't want you to waste your money.
« Last Edit: August 24, 2013, 03:40:33 am by bbob203 »
03 Jetta wagon TDi
Reply #8August 24, 2013, 07:59:51 am
« Reply #8 on: August 24, 2013, 07:59:51 am »
These same shops sometimes put any old oil in the new TDI engines too...what spec? what camshaft? And everyone knows that the 505.xx and up are only to be used.
Just because someone does it doesn't mean it is the right way to do it. I have reused the pp to crank bolts before, but I will not now. Too much riding on it for me.
Reply #9August 24, 2013, 08:12:25 am
bbob203
  • 1789
« Reply #9 on: August 24, 2013, 08:12:25 am »
Its a very busy and reputable shop I even worked there for a few weeks. I would trust any of the techs there to work on my own vehicle. Vw says to replace so many bolts its rediculous. I agree though just because its done doesn't mean its right.. But honestly at this point id trust a reused german bolt over some potentially chinese piece of tin. who knows what you will get.. Moral of the story smoke them if you've got them run them if you don't(want to wait).
03 Jetta wagon TDi
Reply #10August 24, 2013, 09:38:28 am
Dakotakid
  • 1240
« Reply #10 on: August 24, 2013, 09:38:28 am »
Myself, I go with new ones every time.
But, I'll admit it is kind of fun watching lab rats.
Carry on.
Reply #11August 24, 2013, 10:38:26 pm
  • 2926
« Reply #11 on: August 24, 2013, 10:38:26 pm »
 I save the old shoulderless ones for reuse but throw the TTY bolts.
Reply #12August 26, 2013, 02:10:38 am
dave friday
  • 122
« Reply #12 on: August 26, 2013, 02:10:38 am »
Thanks again,I've orderd new bolts!!and the oil seal.
Reply #13August 26, 2013, 07:00:02 am
« Reply #13 on: August 26, 2013, 07:00:02 am »
Just a new seal or the whole flange? The seal alone is a real pain to install without leaking.
Reply #14August 26, 2013, 09:43:26 am
dave friday
  • 122
« Reply #14 on: August 26, 2013, 09:43:26 am »
just the seal,i fitted the seal and housing last time but must have managed to twist the seal lips [i guess ] as the engine is tight [ 14 ft lb to turn the crankshaft at any point in a revolution].
The engine runs ok and has done for 5000miles.
