Author Topic: Fs:1.6td pump, timing tools and more!  (Read 4440 times)
August 20, 2013, 01:59:28 pm
meanvw
  • 46
« on: August 20, 2013, 01:59:28 pm »
1.6 turbo diesel injection pump.  Used and known to work.  Not leaking but comes with a new bosch main shaft seal plus a new vw/bosch seal set for the cold start mechanism.  Also comes with a used set of turbo diesel injection lines.  $200 for all
1.6 diesel timing tool set.  Complete plus 2 new conti timing belts.  $50
Valve shim tool set for any solid lifter/shim vw.  Gas or diesel.  $20
New oil pan gasket/windage tray.  Fits lots of early vw both gas and diesel.  Through atleast mk2's if not more.  $10
Open to package deal/offers.
Located near Milwaukee Wi. Zipcode 53094
Email me for fastest response venomevents(  at  ) yahoo ( dot  ) com
I will take PayPal and will ship (additional cost).  Prices are local pickup .
Reply #1August 20, 2013, 02:14:29 pm
Re: Fs:1.6td pump, timing tools and more!
« Reply #1 on: August 20, 2013, 02:14:29 pm »
PM sent on timing tools, belts and windage tray.
Reply #2August 20, 2013, 04:29:31 pm
« Reply #2 on: August 20, 2013, 04:29:31 pm »
Can i call dibs on the valve shim tools?  And also please explain to me how they work, i have a pretty good idea but id like to know
Reply #3August 20, 2013, 04:52:30 pm
meanvw
  • 46
« Reply #3 on: August 20, 2013, 04:52:30 pm »
More pump pics.  part#068 130 110h
Reply #4August 20, 2013, 05:11:15 pm
meanvw
  • 46
« Reply #4 on: August 20, 2013, 05:11:15 pm »
Got rid of my MK1 bentley, but as I remember, you check the valve lash with a feeler gauge, if it's out of spec then you use the tool with the red handle.  The red handle tool sits on the very edge of the lifter and can be used depress the lifter enough so that the large C shaped pliers can remove the shim from the lifter.  You look at the size of the shim you took out (it's etched on the back side) , and then install a new (usually thicker) shim.  The shims are available from autohausaz.com.  The point of this tool kit is that it allows you to adjust the valves without removing the cam shaft, and monkeying with your timing.
I am traveling tomorrow but will get you shipped price on Thursday.
« Last Edit: August 20, 2013, 05:12:58 pm by meanvw »
Reply #5August 20, 2013, 05:43:00 pm
« Reply #5 on: August 20, 2013, 05:43:00 pm »
Thank you, I really need to stop spending $$$ and this was exactly what I wanted LOL
Reply #6August 20, 2013, 09:20:46 pm
masterbeavis
  • 88
« Reply #6 on: August 20, 2013, 09:20:46 pm »
email sent regarding tools.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #7August 21, 2013, 12:08:37 pm
felipe1f
  • 31
« Reply #7 on: August 21, 2013, 12:08:37 pm »
Hi, if you don't sale the valve shim tools I want them. if sold too bad for me. do you have another one of this tools? the one with the red handle?
Reply #8August 24, 2013, 07:55:49 pm
masterbeavis
  • 88
« Reply #8 on: August 24, 2013, 07:55:49 pm »
I'm waiting on a response regarding the tools, hope he got it.
