Author Topic: 82 Sirocco drive train comparability to Mk 1 Jetta  (Read 9416 times)
Reply #15October 16, 2013, 02:43:46 pm
homerj1
  • 433
Re: 82 Sirocco drive train comparability to Mk 1 Jetta
« Reply #15 on: October 16, 2013, 02:43:46 pm »
I've postponed this late enough.
Just to confirm, will this clutch assembly (82 Scirocco 8v) fit my 1.6td?
From what I can see, it has a diff. size flywheel as a 1.6td?
thanks
Reply #16October 16, 2013, 02:46:50 pm
« Reply #16 on: October 16, 2013, 02:46:50 pm »
yep smaller, 180 or 190mm clutch.. diesel = 200mm stock...
you can run the disk of the gasser in the diesel flywheel too.. just not other way round.. flywheel had to have max disk od machied in it..
other then that same flywheel..
Reply #17October 17, 2013, 02:10:29 am
homerj1
  • 433
« Reply #17 on: October 17, 2013, 02:10:29 am »
Ok,
so the scirocco flywheel and disc and stuff will work - but they in smaller in size ( the disc)
When I do the above change over, I should look for a 1.6td flywheel & buy a new 1.6td clutch kit ( will a 1.9td fit? - I have a few of those).
Otherwise I suspect the smaller clutch won't last as long during "spirited driving"   ;)
Reply #18October 17, 2013, 04:17:10 am
« Reply #18 on: October 17, 2013, 04:17:10 am »
yeah 1.9td is biggest that would be good.  the stock clutches like to slip once you increase boost and fueling
Reply #19October 17, 2013, 08:32:26 am
« Reply #19 on: October 17, 2013, 08:32:26 am »
210mm is biggest 020 clutch... so gasser 1.8/2.0
Reply #20October 17, 2013, 09:56:15 am
« Reply #20 on: October 17, 2013, 09:56:15 am »
thats what aaz has
Reply #21October 18, 2013, 05:34:38 am
« Reply #21 on: October 18, 2013, 05:34:38 am »
some aaz have a 02a with goofy sized non 228mm clurtch too though... smaller then 228 but bigger then 210...
Reply #22October 18, 2013, 06:10:20 pm
« Reply #22 on: October 18, 2013, 06:10:20 pm »
I do believe all AAZ's were 020. The G60 and 1Z/AHU TDI were the only mk3's to get the 02A.
Reply #23October 18, 2013, 07:26:42 pm
« Reply #23 on: October 18, 2013, 07:26:42 pm »
passat..................................................
Reply #24October 18, 2013, 07:33:00 pm
« Reply #24 on: October 18, 2013, 07:33:00 pm »
>>>>>>>>.......................................____________________)))))))))))))))))))))))))
Does he have either of those? ;) AAZ were rare in the passat. 93-95. 96 they got the 1Z.
Reply #25October 18, 2013, 07:58:02 pm
« Reply #25 on: October 18, 2013, 07:58:02 pm »
lucas got one on a aaz he picked up........... so can it happen yes... so i stated 020 to eliminate all silly options....
Reply #26October 19, 2013, 09:23:29 am
homerj1
  • 433
« Reply #26 on: October 19, 2013, 09:23:29 am »
Thanks for all the support & advice.
So
The aaz flywheel, clutch disc & pp will fit my 1.6td and work with a sirocco 5 speed?
Starter-wise will an aaz one fit?
Just trying to make sure I'm going in the right direction, as  my budget is being monitored  by "those who should not be named"  ;D
Aivars
Reply #27October 19, 2013, 01:34:48 pm
Re:
« Reply #27 on: October 19, 2013, 01:34:48 pm »
My AAZ car has its factory 020... Never heard of an 02A behind an AAZ before from VW.
Reply #28October 19, 2013, 06:00:56 pm
Re:
« Reply #28 on: October 19, 2013, 06:00:56 pm »
Yes the aaz stuff will fit and work perfectly.
The one aaz I got had an 02a flywheel that measures 215mm where the disc rides. Don't know if or what it came from. Thinking maybe the Canadian people would know if a Passat or something had it.
Reply #29October 20, 2013, 10:03:33 am
homerj1
  • 433
« Reply #29 on: October 20, 2013, 10:03:33 am »
Thanks for all the help!
The Sircooco is my backup car for finding a 5 speed locally. I do however have an independent  tow truck driver friend who is also looking for me, as I'd like to find a jetta or rabbit diesel.  This fellow knows what is located  where whether  be in  the back 40, buried in a garage somewhere... etc
Although this is also a cool possibility for a  5 speed change over, although the transport costs will easily be $200 + and it would make me feel bad stripping this.
83 Jetta imported from Germany  -   This rig is for sale for $400 in Nova Scotia
