The turbo pump allows fueling under boost so that the air will take care of the egt. Since you aren't adding extra air in the LDA the only way for more fuel is to turn up the pump and gov. mod. It should smoke and have a racing idle by the time you get to the point of worry with an N/A.
And about the pump. I thought the N/A was capable of fueling the same as a turbo pump but that the LDA limits fuel off boost?
Okay yes that's what i figured, but hopefully i'll only be preturbine till october or so It does smoke a little now. Not like crazy. But it does smoke a bit, especially high rpm (3-4000) which doesn't make sense to me since gov should be cutting fuel by then. But whenever I'm on a grade my water temps slowly start creeping up to 210-220 area and that worries me so I back off and go slow up hills aiming for 200ish water temps. But that got me worried that maybe I'm also exceeding EGT temps and since i'll need one when i'm turbo'ed anyway I figure i'll go ahead and throw this one on! Plus I can throw a little more fuel at her and not worry about it. And about the pump. I thought the N/A was capable of fueling the same as a turbo pump but that the LDA limits fuel off boost?
It doesnt allow on boost it simply limits off boost fuel. They flow the same.
Quote from: 8v-of-fury on August 16, 2013, 10:11:39 pmIt doesnt allow on boost it simply limits off boost fuel. They flow the same.Did you seriously just write that? I am done with this one.
Gizmo: That confirms my suspicion then. My water temp gauge is right in the water neck right off the head and does react very quickly to WOT but it still isn't good enough. Better than stock but not an egt gauge. My westach only goes from 700 to 1700 though. Will I see temps above 700 when I'm just cruising? Or only when under lots of load ? What is considered " normal" egts? I know above 1200 is pushing it for max egts but what should I expect just cruising and such?Sent from my ADR6400L using Tapatalk 2
