Author Topic: passat 110 tdi to mtdi but with e vnt 15  (Read 3420 times)
August 15, 2013, 10:41:39 am
snakemaster
  • 405
« on: August 15, 2013, 10:41:39 am »
well i picked up a passat 97 tdi 110hp with the vnt 15 , was looking to put a MTDI pump on her but run all the E parts(exepet injection pump) would the vnt turbo run fine or would it limp out turbo side and not give boost
Reply #1August 15, 2013, 11:20:02 am
Re: passat 110 tdi to mtdi but with e vnt 15
« Reply #1 on: August 15, 2013, 11:20:02 am »
I'm not sure but I think it would limp.  Regardless, you'd need to run the pedal potentiometer and cable along with all of the other engine management.  At that point it seems easier to me to just fit an electronic pump.
Reply #2August 15, 2013, 12:23:52 pm
snakemaster
  • 405
« Reply #2 on: August 15, 2013, 12:23:52 pm »
i am looking to put the engine in my euro van when i have it sorted (only in passat as a test bed ), may copy your mechanical set up for the vnt controler Andrew if this set up works beter for me cheers
