Author Topic: eco diesel cat on mtdi?  (Read 7270 times)
Reply #15August 16, 2013, 04:18:12 pm
homerj1
  • 433
Re: eco diesel cat on mtdi?
« Reply #15 on: August 16, 2013, 04:18:12 pm »
I have a used cat from a 92 eco diesel would it bog down my exhaust flow much if I run it on my passat? I'm sick of stinky exhaust and also hope it can cut down on some cabin noise.
Is a cat the best solution?  What are you currently running for exhaust?
Maybe just some minor change vs installing a cat, could fix your problems.
Reply #16August 16, 2013, 06:37:11 pm
« Reply #16 on: August 16, 2013, 06:37:11 pm »
 ;D
stupid gsser slip joint for cat = leak... th tail pipes dumped so the soot flowed up the cut out in the bumper fo rthe left tow hook... and there is body vent over there.. :D
straight piped now.. it extends past the bumper.. i told him to dimple thepipe.. measure to its end.. see how soot nd all is.. then cut off 1/2" via sawzal and such till he gets soot build up.. then get a nice tip for it and extend it back out to that spot of no soot vs soot.. 2.5" think 125 out door.. i took him to my place who does not harrass me on no cat diesel conversion stuff.. the close to work and maybe better deal would refuse to s no cat..
