Author Topic: plug for oil return on back of AAZ block  (Read 2707 times)
July 31, 2013, 03:21:35 am
ilikevwdiesel
  • 1202
« on: July 31, 2013, 03:21:35 am »
anyone know of a vw fastener that will plug the oil return hole in the back of an AAZ block? going to use a 1.6 oil pan with the return fitting on it so that hole needs to be plugged up.  :D
My Bio
Reply #1July 31, 2013, 04:47:30 am
Re: plug for oil return on back of AAZ block
« Reply #1 on: July 31, 2013, 04:47:30 am »
3/4" copper pipe cut to about 1" long and then use the stock banjo bolt. That should work as long as it's not in your way.
Reply #2July 31, 2013, 04:51:59 am
ilikevwdiesel
  • 1202
« Reply #2 on: July 31, 2013, 04:51:59 am »
that's brilliant tyler thanks  :)
My Bio
Reply #3July 31, 2013, 05:34:11 am
bbob203
  • 1789
« Reply #3 on: July 31, 2013, 05:34:11 am »
Why not just get a stubby bolt or cut one off thats the same size/thread as the hole and run a copper washer on it?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4July 31, 2013, 05:45:58 am
ilikevwdiesel
  • 1202
« Reply #4 on: July 31, 2013, 05:45:58 am »
that's brilliant as well. Thanks!  :)
My Bio
Reply #5August 02, 2013, 03:18:46 pm
CrazyAndy
  • 739
« Reply #5 on: August 02, 2013, 03:18:46 pm »
You could even use the old copper washer from the oil return banjo bolt; I've found you can turn them around and they usually will re-conform.
If I may play devil's advocate:  You could also use the top end of the turbo oil drain and splice it into the AAZ block-side drain end.  That is, of course, assuming you are doing this out of preference, or don't have an AAZ pan.  Also, don't forget the AAZ block is taller than a 1.6, so using the stock line won't work unless you use an extension of some sort.
