Author Topic: Vacuum pump o-ring?  (Read 4452 times)
Reply #15August 03, 2013, 06:06:35 am
Re: Vacuum pump o-ring?
« Reply #15 on: August 03, 2013, 06:06:35 am »
Torque for most any 6mm bolt is like 7ft/lbs if you are going dry. Less if it is low carbon and more if it is 12.9 grade. It would probably be easier to use inch pounds to get a more accurate reading. Also, for this application I have not torqued them, I just snugged them up. I am all for torque values though so if the Bentley has them I would use them. If the Bentley doesn't have a spec then it really isn't needed. It has specs for everything.
Reply #16August 03, 2013, 09:19:51 am
jaed_43725
« Reply #16 on: August 03, 2013, 09:19:51 am »
I torqued to 10 ft/lbs and installed. And now it works great. The only thing I did was replace the o-ring on the bottom and the one under the lid.
