Author Topic: Tallest 5th gear possible  (Read 6492 times)
Reply #15July 26, 2013, 05:22:38 pm
bbob203
  • 1789
Re: Tallest 5th gear possible
« Reply #15 on: July 26, 2013, 05:22:38 pm »
Absolutely.  If I had an AVX in an ECO I would most certainly swap it out along with the injection pump and the soda straw exhaust...
The eco exhaust is at least bigger than an na exhaust.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #16July 26, 2013, 09:10:28 pm
Jetmugg
  • 530
« Reply #16 on: July 26, 2013, 09:10:28 pm »
Get taller tires.
Reply #17July 26, 2013, 10:08:27 pm
Gizmoman
  • 1301
« Reply #17 on: July 26, 2013, 10:08:27 pm »
That's what I did on the van - works good but it raises all of 'em.
I have a K14 and getting the breadbox rolling up a hill from a dead stop is trickey.
I'm speaking from memory though - I'ts been in rebuild mode for over a year ;D
Reply #18July 27, 2013, 10:08:32 am
92EcoDiesel Jetta
« Reply #18 on: July 27, 2013, 10:08:32 am »
Get taller tires.
Is the results the same as changing final drive at same rpm?
Reply #19July 27, 2013, 10:25:47 am
« Reply #19 on: July 27, 2013, 10:25:47 am »
175/70/13 with 3.94 and .71 is 2500 @ 60 - with 3.67 and .71 is 2300
185/70/14 with 3.94 and .71 is 2300 @ 60 - with 3.67 and .71 is 2100
Reply #20July 27, 2013, 11:09:03 am
92EcoDiesel Jetta
« Reply #20 on: July 27, 2013, 11:09:03 am »
Aerodynamics aside from bigger tires provided there is no interference in wheel wells, seems much easier than changing the diff to lower rpm.
Reply #21July 27, 2013, 11:36:50 am
« Reply #21 on: July 27, 2013, 11:36:50 am »
There are more significant downsides to larger tires than aerodynamics, most notably the added rotating mass hurts fuel economy during acceleration (similar to added weight in the car) and makes the brakes less effective (similar to added weight in the car).  It's a better idea to get close with gearing and fine-tune with small changes in wheel/tire size.  When you consider the cost of used larger rims and new tires the cost is more than a good used trans.  Swapping a trans is a little more work than swapping 4 tires.  The trans you pull out can usually be sold for close to or the same as what you pay for the taller geared one - there are certainly folks who want the close ratios for added pep.  Used 13" rims and tires are hard to give away and go bad on the shelf.
Reply #22July 27, 2013, 02:42:36 pm
92EcoDiesel Jetta
« Reply #22 on: July 27, 2013, 02:42:36 pm »
If rotating mass is an issue why are new cars going with bigger and bigger wheels? Why not go the other way?
Reply #23July 27, 2013, 03:24:40 pm
« Reply #23 on: July 27, 2013, 03:24:40 pm »
The short answer is that cars have gotten heavier to accommodate stricter safety requirements and given two sizes of the same model of tire with the same aspect ratio, the larger size will carry a higher load rating.  Heavier cars = bigger tires.  Newer cars also have much larger brakes to accommodate stopping both the heavier car and the bigger tires...
« Last Edit: July 27, 2013, 03:27:03 pm by libbydiesel »
Reply #24July 27, 2013, 06:43:33 pm
CrazyAndy
  • 739
« Reply #24 on: July 27, 2013, 06:43:33 pm »
Also the trans final drive is selected with both engine power, vehicle weight and wheels' tire size taken into accommodation.  That's why the 2013 passat TDI rides at 70mph @ 2250 on a relatively flat beltway-style freeway and has good power.
Reply #25July 27, 2013, 07:50:57 pm
« Reply #25 on: July 27, 2013, 07:50:57 pm »
Those bigger alloy wheels are probably still not that much heavier than our thick gauge steel rims.
I didn't notice any hit in mileage or performance when going from the 175/70/13 to the 185/65/14's on the mk2.
