Author Topic: Did I bend valves? (I'm an idiot)  (Read 6600 times)
July 03, 2013, 08:09:17 am
Smoker
  • 255
« on: July 03, 2013, 08:09:17 am »
So while assembling the ahu in a mk3, I didn't completely have my head in the game... I had the bottom end at tdc... The cam caps were all loose, and I started to torque them down without taking notice of what position the cam was in. Result: I tightened the caps, pushing valves into pistons. I didn't torque them to 400 ft-lbs or anything, but enough to make me nervous. So obviously I won't know till I try to start it, but what do you guys think? Just hoping someone can set me at ease...
Sent from my SCH-I545 using Tapatalk 2
Reply #1July 03, 2013, 08:38:01 am
81 vw pu
Re: Did I bend valves? (I'm an idiot)
« Reply #1 on: July 03, 2013, 08:38:01 am »
Since you state bottom end was at tdc cylinders 1&4 are the only ones that could have bent valves if the engine was not turned.
I would remove cam and do a leakdown test.
Reply #2July 03, 2013, 08:52:27 am
« Reply #2 on: July 03, 2013, 08:52:27 am »
replace lifter and valves that hit... to pop the valve head off while driving will cost you head, injector, piston, possible rod... vs a valve or 2 now...
even if they look straight.. 7mm hardened steam on valve.. a stresser in it that you annot see can allow it to fail.. simple.. if it hit replace it
« Last Edit: July 03, 2013, 08:54:18 am by CRSMP5 »
Reply #3July 03, 2013, 09:14:45 am
Smoker
  • 255
Re: Re: Did I bend valves? (I'm an idiot)
« Reply #3 on: July 03, 2013, 09:14:45 am »
Well, that's exactly what I needed to know... guess I'll be pulling the head tonight
Reply #4July 03, 2013, 09:59:54 am
« Reply #4 on: July 03, 2013, 09:59:54 am »
i guess id rather put a few hours and a couple more bucks(probably what 100 until u buy 2 valves 2 lifters and a head gasket?) into it than to find out down the road that i did some serious damage
but, was there anything holding the piston in place?  it may have just pushed down out of the way as you tightened it right?
Reply #5July 03, 2013, 10:29:44 am
« Reply #5 on: July 03, 2013, 10:29:44 am »
ll my experiance..
1.6na... free engine.. 8k later.. pop.. you could see in past life it hit piston via other pistons.. used head/rod/piston cheap easy to find.. look for tdi parts...
16v 2.0 i sell head via portex in 01.. i do valve job and pack/ship.. not 1st head ive ever shipped.. it dropped #8 intake valve thru piston.. all i can figure is shipper dropped that head on that corner, tweeked a valve.. and 2 weeks later i buying new engine.. :( those 7mm stems...
why i say change the ones you think hit.. may work for now.. but grenade pin pulled...
Reply #6July 03, 2013, 12:15:15 pm
Smoker
  • 255
Re: Re: Re: Did I bend valves? (I'm an idiot)
« Reply #6 on: July 03, 2013, 12:15:15 pm »
There was nothing holding it, but I'd imagine you could push pretty hard on a piston when it's at tdc and not move it.
Reply #7July 03, 2013, 12:17:58 pm
Smoker
  • 255
« Reply #7 on: July 03, 2013, 12:17:58 pm »
On to the next question... I just had my injectors tested, and found that I have a bad one. There's a local guy parting out an 02 golf... are ahu and alh injectors interchangeable?
So far this is not turning out to be my day.
Reply #8July 03, 2013, 01:07:58 pm
« Reply #8 on: July 03, 2013, 01:07:58 pm »
AHU and ALH injectors are the same.
Reply #9July 03, 2013, 02:47:39 pm
81 vw pu
« Reply #9 on: July 03, 2013, 02:47:39 pm »
The alh injectors have two different stock nozzle sizes and injection pumps depending on if the car was an automatic or manual trans. Not sure of the ahu.
