Author Topic: tips on swapping tdi injectors Copper washer stuck Solved  (Read 12640 times)
Reply #15June 24, 2013, 08:36:35 pm
Smoker
  • 255
Re: Re: Re: tips on swapping tdi injectors
« Reply #15 on: June 24, 2013, 08:36:35 pm »
I made my own using spare Vw parts kicking around the shop. The only part not pictured is a 02A flywheel for more weight.
Ha. Awesome. Maybe I just need to weld more weight onto my slide hammer.
Sent from my SCH-I545 using Tapatalk 2
Reply #16June 24, 2013, 08:47:51 pm
  • 4551
« Reply #16 on: June 24, 2013, 08:47:51 pm »
That is the rule of all good mechanics.  Give me a bigger hammer.  That ought to fix it real good.
Reply #17June 25, 2013, 11:48:51 am
« Reply #17 on: June 25, 2013, 11:48:51 am »
Yes even with 20 lbs I still had to hammer one of them 15+ times before it came out  :o
Reply #18June 25, 2013, 03:23:44 pm
bbob203
  • 1789
« Reply #18 on: June 25, 2013, 03:23:44 pm »
Don't use qtips... :-[
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #19June 26, 2013, 01:52:29 pm
bbob203
  • 1789
« Reply #19 on: June 26, 2013, 01:52:29 pm »
looking for tips on getting stuck copper washer out.
03 Jetta wagon TDi
Reply #20June 26, 2013, 07:40:41 pm
Re: tips on swapping tdi injectors Copper washer stuck
« Reply #20 on: June 26, 2013, 07:40:41 pm »
Is the head on or off the engine?
Reply #21June 27, 2013, 12:35:35 am
bbob203
  • 1789
« Reply #21 on: June 27, 2013, 12:35:35 am »
on
03 Jetta wagon TDi
Reply #22June 27, 2013, 03:45:09 am
« Reply #22 on: June 27, 2013, 03:45:09 am »
Use a pick to clear out as much carbon as you can then tap it with a small punch. It should break free. You might be able to thread a bolt onto it if its ID is smaller than the nozzle hole.
Reply #23June 27, 2013, 03:39:40 pm
bbob203
  • 1789
Re: tips on swapping tdi injectors Copper washer stuck Solved
« Reply #23 on: June 27, 2013, 03:39:40 pm »
Used a cv axle xzn 8mm bolt to get it out worked awesome.
03 Jetta wagon TDi
Reply #24June 30, 2013, 04:09:41 am
« Reply #24 on: June 30, 2013, 04:09:41 am »
So you hammered if in and tried unscrewing it basically?
Reply #25June 30, 2013, 05:57:56 am
bbob203
  • 1789
« Reply #25 on: June 30, 2013, 05:57:56 am »
I tapped on it to get a little bite into the copper then screwed it CW until it hit the alluminum and pulled and wiggled and it came out.
03 Jetta wagon TDi
Reply #26June 30, 2013, 08:45:30 pm
« Reply #26 on: June 30, 2013, 08:45:30 pm »
I see. You didn't use the triple square tool, but a M8x1.25 bolt.
Reply #27July 01, 2013, 05:37:14 am
bbob203
  • 1789
« Reply #27 on: July 01, 2013, 05:37:14 am »
No i used the xzn headed bolt and the triple square tool the key is that the xzn bolt had the taper on the end.
03 Jetta wagon TDi
