Author Topic: tips on swapping tdi injectors Copper washer stuck Solved  (Read 12640 times)
June 14, 2013, 12:12:50 pm
bbob203
  • 1789
« on: June 14, 2013, 12:12:50 pm »
going to be tossing in some re man injectors with pp520 nozzles done by DBW llc. tips on pulling and installing?
« Last Edit: June 27, 2013, 03:38:54 pm by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1June 14, 2013, 12:41:09 pm
Re: tips on swapping tdi injectors
« Reply #1 on: June 14, 2013, 12:41:09 pm »
look down in this section at stuck injector... thats the only tip..
Reply #2June 15, 2013, 04:36:21 am
dieselherb1
  • 354
« Reply #2 on: June 15, 2013, 04:36:21 am »
clean around inj. bodies(air) spray some PB Blaster or Kroil oil around them night before. I use a older slide hammer dent puller. Put a 1/4" bolt thru a inj. line cap into the slider hammer cap then thread on to inj. you want to pull(head must be bolted on engine or to something heavy) normally 2-3 pulls they're out. Tried it once with head on the ground, played with it for hours gave up come back later still no luck bolted it back on block. 5 minutes all inj out. I've had my slide hammer for many years. I see the newer ones are lighter weight. I think mine is 4-5 lbs.
Reply #3June 15, 2013, 09:51:30 pm
« Reply #3 on: June 15, 2013, 09:51:30 pm »
I got 3 of the 4 out with channel locks, with out too much trouble.
I eventually got number 4 too, but it was a lady of the evening.
Reply #4June 15, 2013, 09:56:42 pm
« Reply #4 on: June 15, 2013, 09:56:42 pm »
<------shaking head... why did you not twist it with a wrench? think 17m fits it perfect.. even has the curve of th einjector body to fill the curve of the wrench.. seriously.. they made ot use a wrench on them..
Reply #5June 16, 2013, 11:38:14 am
Re: Re: tips on swapping tdi injectors
« Reply #5 on: June 16, 2013, 11:38:14 am »
I read that the injector nozzles have some small pins that align them to the injector body. If the nozzle itself is stuck and you twist the body with a wrench all the force is put on those small pins potentially breaking them. If you break em you need to replace the injector body.
That said, I used the wrench method to remove my injectors in my TDI head.
Sent from my HTC One X using Tapatalk 2
Reply #6June 16, 2013, 02:13:36 pm
« Reply #6 on: June 16, 2013, 02:13:36 pm »
The tip and top portion of the injector are separated by clamping that 17mm area and unscrewing the tip.  My one caveat for trying to undo them with a wrench is that you should always rotate CW or you run the risk of unscrewing the two parts of the injector.
Reply #7June 16, 2013, 02:25:05 pm
« Reply #7 on: June 16, 2013, 02:25:05 pm »
When this happens.. good luck getting the rest of the injector out :) lol.
Reply #8June 16, 2013, 03:25:11 pm
bbob203
  • 1789
« Reply #8 on: June 16, 2013, 03:25:11 pm »
or just screw it in and use a slide hammer.
03 Jetta wagon TDi
Reply #9June 16, 2013, 03:28:13 pm
« Reply #9 on: June 16, 2013, 03:28:13 pm »
alright good luck not loosing the 13 minuscule pieces then haha.
Reply #10June 16, 2013, 05:00:56 pm
« Reply #10 on: June 16, 2013, 05:00:56 pm »
dude i only shook my head as channel locks were used... wrench better then that... now that i have slide hammer set up tool.. i use it.. :P
Reply #11June 16, 2013, 05:29:04 pm
« Reply #11 on: June 16, 2013, 05:29:04 pm »
No leverage on the wrench, and it was slipping off bending open my wrenches! lol
Reply #12June 19, 2013, 08:59:40 pm
Smoker
  • 255
« Reply #12 on: June 19, 2013, 08:59:40 pm »
I'm still stuck on mine... even the side hammer won't budge them. Not sure what to do next.
Sent from my SCH-I545 using Tapatalk 2
Reply #13June 20, 2013, 12:27:27 am
bbob203
  • 1789
« Reply #13 on: June 20, 2013, 12:27:27 am »
I went to oreillys and bought a big slidechammer and made an adapter out of 2 nuts and a welder. this way I can keep the adapter and return the slide hammer when I'm done. I like the rental tool feature helps keep down the clutter in my garage.
03 Jetta wagon TDi
Reply #14June 24, 2013, 08:01:19 pm
« Reply #14 on: June 24, 2013, 08:01:19 pm »
I made my own using spare Vw parts kicking around the shop. The only part not pictured is a 02A flywheel for more weight.
