Author Topic: FS: 1.6 TD parts Come inside for prices/pictures. Prices dropped, lets bargin!!  (Read 6892 times)
June 14, 2013, 10:59:04 am
justiz00
  • 54
1.6 Turbo diesel project selloff. Trying to get my wife into a new car so time to clean out the closet (almost literally). All of the new parts have been stored indoors in a spare bedroom. Located in Central Texas and prices in US dollars. Prices are before shipping to the Continental US, Canada and elsewhere PM me and I will go buy and check on a price (EXCEPT WHERE NOTED). Everything except the heavy odd shaped stuff will be shipped USPS flat rate priority. Other stuff is UPS.
Payment thru Paypal. PM me for details. Prices are negotiable.
Derale Thermostat Kit #25719      $25
Scch Lightened/Balanced 1.6TD crankshaft   $225  Rods and Mains are still Std. Stored upright in
a bag indoors (PM your zip code for accurate shipping quote)
Rosten 1.6td H-beam rods w/ARP bolts   $250
Water pump with metal impeller and housing   $30
Water pump to housing metal gasket      Sold
Freeze plugs set (4 large, 2 small)      Sold
Kolbenschmidt 1mm over 1.6TD pistons   Ceramic coated on top and poly coated on skirts, includes pins and rings SOLD
Plastic Meyle thermostat housing      Sold
High volume oil pump         Sold
V/C Oil Deflector            Sold
Plastic Rear window louvers, not brittle but old. Pulled from same car as the aux. fuel tank. Can meet within reasonable distanct. Shipping would be high. With hardware.  $75
Jetta MK1 flares that were trimmed in the rear to fit a rabbit. The right rear is cracked (see pictures). Will throw in mudflaps with hardware also. Shipping will have to be checked on.  $50
Turbo setup sold except for turbo pump and cast toilet bowl downpipe
$250 pump (Will be removed from the car this weekend 8-3 to 8-4)
Justice
PM me for detail on any of it. Will ship on Monday, Wed, Thurs, Fridays and Saturdays (UPS), because of work/school schedule.
« Last Edit: August 05, 2013, 12:42:51 am by justiz00 »
Reply #1June 14, 2013, 04:04:08 pm
felipe1f
  • 31
Re: FS: 1.6 TD project selloff Come inside for prices and pictures.
« Reply #1 on: June 14, 2013, 04:04:08 pm »
Hi, what brand is the 80 degrees thermostat, how much for shipping to 90262?
Reply #2June 14, 2013, 04:12:41 pm
justiz00
  • 54
« Reply #2 on: June 14, 2013, 04:12:41 pm »
pm sent
Reply #3June 18, 2013, 12:15:00 pm
RustyCaddy
  • 395
« Reply #3 on: June 18, 2013, 12:15:00 pm »
Got the head studs and they were as described...super fast shipping.
Thanks and bump for a good seller
 ;D
Reply #4June 18, 2013, 12:54:13 pm
nwcali6
  • 69
« Reply #4 on: June 18, 2013, 12:54:13 pm »
 turbo and exhaust manifold?  I didn't see them but I might have missed them if they were there...
  Thanks
Reply #5June 18, 2013, 02:38:07 pm
justiz00
  • 54
« Reply #5 on: June 18, 2013, 02:38:07 pm »
The turbo and manifold have been sold sorry. Thanks for looking.
Justice
Reply #6June 27, 2013, 08:11:05 pm
Dieseltdi
  • 33
    • http://mysite.verizon.net/resosxp8/mydieselpages/
« Reply #6 on: June 27, 2013, 08:11:05 pm »
PM sent
2020 Chevrolet Baby Duramax
2013 Jetta Sportwagen TDI
1957 unrestored VW Oval Window Bug
1982 Vanagon Westfalia with AHU TDI conversion
Reply #7June 28, 2013, 01:02:37 am
justiz00
  • 54
Reply #8June 28, 2013, 05:54:36 am
« Reply #8 on: June 28, 2013, 05:54:36 am »
I want everything you have, but cannot afford it.
If you want to deal a bit as it will all be shipped together and I need to convince the wife, how much for the main studs, girdle, and fox oil fliter mount. PM me if you want. I am interested for my jeep build. The girdle should fit a 1.9 I think, but I may need to cut on it.
Reply #9July 29, 2013, 02:14:09 pm
justiz00
  • 54
Dropped prices, lets make a deal!!
Justice
Reply #10July 29, 2013, 07:24:45 pm
I got the stuff, thanks
Reply #11July 29, 2013, 07:59:30 pm
justiz00
  • 54
I saw it was delivered. Thanks for the purchase.
Justice
Reply #12August 02, 2013, 01:51:04 pm
felipe1f
  • 31
Hi justin, what brand is the water and oil pump? is the thermostat housing at a 45 degree angle? what car was all this parts intended for?
Reply #13August 02, 2013, 02:33:00 pm
justiz00
  • 54
Oil Pump-Schadek 36mm pump Parts place
Water Pump-Graf 30mm pump Rabbit Parts
Thermostat housing-Meyle Yes the inlet is rotated 45* from the mounting holes.
Originally intended for MK1 1.6/1.9 turbo diesel in an 81 Rabbit.
Reply #14August 02, 2013, 06:45:14 pm
felipe1f
  • 31
I want to buy the oil deflector and meyle thermostat housing. how much for shipping to California 90262?
would you take $38 for the oil pump? I am not sure if it fits my vanagon, but I can use it for may jetta.
