Author Topic: Exhaust gasket 85TD  (Read 2339 times)
June 05, 2013, 08:02:42 pm
dieselherb1
  • 354
Exhaust gasket 85TD
« on: June 05, 2013, 08:02:42 pm »
I need the turbo to manifold gasket,1.6TD(T3 turbo) trapazoid mount. Who sells it and what is part#
Reply #1June 05, 2013, 08:53:51 pm
  • 2932
Re: Exhaust gasket 85TD
« Reply #1 on: June 05, 2013, 08:53:51 pm »
I don't think that needs a gasket.
Reply #2June 05, 2013, 10:27:54 pm
« Reply #2 on: June 05, 2013, 10:27:54 pm »
I think Prothe sells them (on ebay) but I don't believe there was one there from the factory.
Reply #3June 06, 2013, 12:34:59 am
« Reply #3 on: June 06, 2013, 12:34:59 am »
His turbos probably  aren't flat enough to seal.
Reply #4June 06, 2013, 11:56:18 am
damac
  • 531
« Reply #4 on: June 06, 2013, 11:56:18 am »
My first vw like 4 years ago was an 85 jetta turbo and it only had the gasket on the downpipe side.
Not one turbo motor I have come across since has had a gasket there and I never thought about it after reading around some forums.
Kind of wierd considering it doesn't seem like those pieces are very flat.  I just clean everything and spray some copper gasket lightly on each surface during reinstall and I haven't had a boost leak in any of them.
1985 turbo diesel jetta
Reply #5June 06, 2013, 02:14:58 pm
justiz00
  • 54
« Reply #5 on: June 06, 2013, 02:14:58 pm »
I have run his gasket set (turbo and dp) and they seal nicely. At 5 or 6 bucks why not. I needed to replace the dp side anyways.
