Author Topic: Is this a good M-TDI doner?  (Read 3751 times)
June 04, 2013, 06:19:55 pm
camboscams
  • 324
« on: June 04, 2013, 06:19:55 pm »
So i can get my hands on a 98 tdi manual beetle for around 1200 bucks. I have not laid eyes on the odometer (dead battery) but the owner thinks it under 100000 so thats a plus.
So due to my unfamiliarity with tdi's which is soon to change, is this the setup that works well with a MK1 swap?
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1June 04, 2013, 07:13:50 pm
Re: Is this a good M-TDI doner?
« Reply #1 on: June 04, 2013, 07:13:50 pm »
jetta will be more simple then bug for a mk1... the waterpump set up is like a mk4 requiring custom timming belt end mount that is well overpriced at nothing leaves stock... but sadly only way to do it
Reply #2June 04, 2013, 07:20:50 pm
camboscams
  • 324
« Reply #2 on: June 04, 2013, 07:20:50 pm »
So better off with a jetta setup? even considering it is a low milage unit?
So having said that what would be a reasonable price for a virginia located tdi?
Reply #3June 04, 2013, 07:48:06 pm
« Reply #3 on: June 04, 2013, 07:48:06 pm »
I think 1000-1500 is a good price
The older tdis are easier to swap to a mk1.  The 1z and ahu came in passats and mk3 jettas and u can bolt a ml1 mount to them if u use a manual tensioner and trim out the tbelt cover.
Mk4/beetle will work too and is a good engine but like chris said the passenger side motor mount needs to be bought or made.  But also a land rover pump is nearly a bolt on.
Theyll both work and honestly i wouldnt shy away from a beetle swap if u no the engines in good order
Reply #4June 04, 2013, 10:13:15 pm
« Reply #4 on: June 04, 2013, 10:13:15 pm »
vnt too... so not as simple.. but yes can be done.. th issue is no way to mod a mk1 mount to fit.. look at what nls sells for that mount.. to copy.. not simple.. i could do it... just gotta take it into acct..
Reply #5June 05, 2013, 08:59:37 am
bbob203
  • 1789
« Reply #5 on: June 05, 2013, 08:59:37 am »
I have heard that some early beetles had wastegate turbo.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #6June 05, 2013, 06:09:46 pm
camboscams
  • 324
« Reply #6 on: June 05, 2013, 06:09:46 pm »
This particular car has the vnt... Well I think when the time comes i'll go the Libby injection pump route, which i don't think will benefit the almost bolt on of the rover pump will it?
Reply #7June 05, 2013, 07:12:24 pm
« Reply #7 on: June 05, 2013, 07:12:24 pm »
Andrew's pump will far out do the Rover pump in every way.
It is brand new, zero miles, and tuned to run this engine perfectly.
The rover will NEED a reseal, and NEED tuning.. it will likely also NEED modification of some sort.
Reply #8June 05, 2013, 07:27:23 pm
« Reply #8 on: June 05, 2013, 07:27:23 pm »
look at it like this....
libby = more.. but new/service if issue...
rover = cheap... roll the dice.. if needs rebuilt/fixed libby was better deal..
i was rover guini pig.. mine i traded e stuff for.. so no cost to give it a try... if i got burned.. easy.. send off and get fixed.. same cost...
