Author Topic: What do I have and will it work??? (Turbo question)  (Read 3657 times)
May 31, 2013, 12:55:36 pm
masterbeavis
  • 88
« on: May 31, 2013, 12:55:36 pm »
This turbo was given to me by a buddy. It was off of a Quantum diesel. (Rear wheel drive). I will try to upload pics, all I know is its a Garret.
Will the exhaust clear my booster/shift linkage with a tight bend on the exhaust?
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #1May 31, 2013, 01:05:57 pm
masterbeavis
  • 88
Re: What do I have and will it work??? (Turbo question)
« Reply #1 on: May 31, 2013, 01:05:57 pm »
No dice on the upload, but the tag on the turbo reads as follows:
068145703B
465384 1
KG 0332 A
Reply #2May 31, 2013, 01:46:41 pm
« Reply #2 on: May 31, 2013, 01:46:41 pm »
The Quantums were front wheel drive or all-wheel drive.  No rear wheel drive mk1s or mk2s other than the vanagon.
Regardless, if it came off a Quantum it will definitely work on a Quantum.  If your vehicle isn't a quantum you might have issues.
Reply #3May 31, 2013, 01:59:17 pm
masterbeavis
  • 88
« Reply #3 on: May 31, 2013, 01:59:17 pm »
Some research on the web tells me its a Garrett TAO304, but not much else.
Reply #4May 31, 2013, 02:03:19 pm
masterbeavis
  • 88
« Reply #4 on: May 31, 2013, 02:03:19 pm »
My friend says Quantum, but it could be a Fox??  I have seen vw's with the motor installed longways.
The vehicle it may go into is an '81 Caddy 1.6 NA.
Reply #5May 31, 2013, 02:12:35 pm
DanV990
  • 20
« Reply #5 on: May 31, 2013, 02:12:35 pm »
The Quantum's engine was mounted longitudinally instead of transversely like the Rabbit, Golf & Jetta so you may need to get creative with your exhaust plumbing.
Reply #6May 31, 2013, 03:39:56 pm
« Reply #6 on: May 31, 2013, 03:39:56 pm »
Yes, the fox, dasher, quantum were all longitudinal but still front wheel drive.  The turbo will work with the typical golf/jetta manifold.  I'm not sure if it will work with the longitudinal manifold.
Reply #7May 31, 2013, 04:29:17 pm
« Reply #7 on: May 31, 2013, 04:29:17 pm »
I dont think it will work on the quantum exhaust manifold
Reply #8May 31, 2013, 05:26:21 pm
« Reply #8 on: May 31, 2013, 05:26:21 pm »
I should also qualify my previous statement that it will work with the jetta/golf manifold.  It will, but you will need  to re-clock the center section and compressor scroll which can be a significant task if bolts break.
Reply #9May 31, 2013, 11:37:08 pm
« Reply #9 on: May 31, 2013, 11:37:08 pm »
You also need a transverse thermostat housing.
