Author Topic: Kooky idea??? Using a distributor to trigger a tach signal...  (Read 5877 times)
Reply #15May 31, 2013, 05:53:15 am
Gizmoman
  • 1301
Re: Kooky idea??? Using a distributor to trigger a tach signal...
« Reply #15 on: May 31, 2013, 05:53:15 am »
Kooky is right. You would also need to add an ignition coil and power it for it to work.
Not true if he used a sensor on the distributor rotor and ground off three of the four lobes. I don't think he was planning on using a distributor with points. He would still need a way to convert the signal from the sensor into a valid number though.
Reply #16May 31, 2013, 10:37:16 am
Jetmugg
  • 530
« Reply #16 on: May 31, 2013, 10:37:16 am »
I have come to the realization that the idea is too Kooky to be practical.  I would have gladly run an electronic distributor and coil, just for the purposes of triggering a tach signal.
I'm building a dedicated race truck that will see very few miles.
The Ford (or equivalent) magnetic sensor looks like a pretty solid idea.
The optical sensor measuring at the cam sprocket seems OK, too.
Right now, I'm seriously thinking about buying one of those digital tiny tachs.
Steve.
Reply #17May 31, 2013, 11:02:22 am
« Reply #17 on: May 31, 2013, 11:02:22 am »
There was someone on here who used an optical sensor and a couple of white marks on the IP pulley - the sensor had its own light source and picked up the reflections.  You could also mount a couple of magnets to the IP pulley quite easily if you wanted to go the magnetic route.
Reply #18May 31, 2013, 12:44:00 pm
Reply #19June 01, 2013, 01:07:34 am
Re: Re: Re: Kooky idea??? Using a distributor to trigger a tach signal...
« Reply #19 on: June 01, 2013, 01:07:34 am »
http://www.4crawler.com/Diesel/CheapTricks/Tachometer/index.shtml
Bingo. That is exactly the setup I was thinking about.
Sent from my HTC One X using Tapatalk 2
Reply #20June 03, 2013, 06:18:25 pm
« Reply #20 on: June 03, 2013, 06:18:25 pm »
Steve.
i dont like having the sensor that close to my timing belt. ive already had one sensor come apart on me, i dont want it to be able to come apart, and break my timing belt..
getting the reading directly from the crank with an external sensor is a little less prone to failure, if you ask me.."
my crank trigger tach idea was based off the photo-electric tach.. but highly modified..
all i had to do, was tach 2 nuts on my crank pulley, build a bracket for the sensor, and run wiring..
plus, you can use this method to drive almost any gasser 4 cylinder tach..
Reply #21June 04, 2013, 04:35:51 am
« Reply #21 on: June 04, 2013, 04:35:51 am »
racer.... libby help me...
i know for one snap on sold a contraption you inerted in the glow plug hole... to run a timming light.. a normal old school timming light.. old early 80s tech.. only seen used 1 time...
why libby... i know he is using something like this for a timming light... you no need 4 glowplugs on a racer... install the tool as a tach signal you can also use to set ideal pump timming...
