General Information
Upgrades (non engine related )
New Seats for Caddy
Topic: New Seats for Caddy (Read 4555 times)
May 25, 2013, 04:38:05 am
rs899
New Seats for Caddy
May 25, 2013, 04:38:05 am »
It's time (past time, really) to do this.
What are some good candidates to cannibalize seats from?
Whats in there now are irreplacable! When was the last time you saw a Renault Fuego in a boneyard?
I might even go for a bench seat this time.
Any ideas?
'91 Jetta 1.6 NA, '82 Caddy 1.6NA, '81 Cabriolet, 4 Mercedes OM616/617s , 2 Triumphs and a Citroen DS19 in a pear tree.
May 25, 2013, 10:01:16 am
Moderator
4552
Re: New Seats for Caddy
May 25, 2013, 10:01:16 am »
If you really like the current ones what is the cost to get them recovered?
May 25, 2013, 11:56:33 am
shwak23
Re: Re: New Seats for Caddy
May 25, 2013, 11:56:33 am »
Getting seats recovered is almost never worth the cost. I think it is usually $800+. Unless you plan to keep the car forever or just don't care about money.
Sent from Outer Space!
May 25, 2013, 05:33:59 pm
Moderator
4552
May 25, 2013, 05:33:59 pm »
You need to find a "reasonable" upholsterer. Have them make the covers and you do the padding and the attaching. It isn't that hard. Think of it like rolling up a sock and getting the tip on the toes nice and straight and just work it down the back from there. Bottom parts are even easier as you have to start at the front and tighten them off in the back.
May 26, 2013, 04:10:13 pm
shwak23
May 26, 2013, 04:10:13 pm »
It certainly isn't hard to take off and put on the fabric. Or even replacing the foam yourself. But having someone make new jackets and covers.... that is never cheap.
May 28, 2013, 03:40:23 am
rs899
May 28, 2013, 03:40:23 am »
That ain't gonna happen until the seats in SWMBO's 380SL get the royal treatment.
I am looking for known workable $20 junkyard seats. I have a pair of Miata seats up in the rafters that should probably work, but I was saving them for the Spitfire.
June 01, 2013, 06:35:09 pm
GEE-BEE
June 01, 2013, 06:35:09 pm »
G60 corrado seats and brakes, I paid 400.00
did a new mkii16v booster and 16v master cylinder, MKII pedal assy
I used the brake lines from a new cabby in S/S perfect from mk1autohaus
Seats were recovered with new old stock scirooco 16v material from mk1autohaus
best seat
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
General Information
New Seats for Caddy
