Author Topic: messed up...  (Read 2418 times)
March 08, 2006, 12:55:30 pm
jwspin
  • 138
messed up...
« on: March 08, 2006, 12:55:30 pm »
when rebuilding a k14 turbo i messed up. i put the washer on top of the thrust bearing and cracked the compressor backing plate a bit. the crack is a hairline and connects the dots between three of the bolt holes. the washer ended up pushing up on the center section and thats what caused the crack. do you think it will be oke to run it because there isnt much pressure on the plate or do i need a new one?
does anyone have any parts turbos?
-jared
