Author Topic: Boost response?  (Read 7102 times)
Reply #15May 25, 2013, 06:28:35 am
jaed_43725
Re: Boost response?
« Reply #15 on: May 25, 2013, 06:28:35 am »
It worked a little bit. I think at this time I really need a DP though.
Reply #16May 25, 2013, 11:44:05 am
Re: Boost response?
« Reply #16 on: May 25, 2013, 11:44:05 am »
Mine spooled up pretty fast with a closed wategste and stock cast dp and was capable of 25psi
Reply #17May 28, 2013, 05:38:34 pm
jaed_43725
Re: Boost response?
« Reply #17 on: May 28, 2013, 05:38:34 pm »
Is there a really good person for these turbos? Someone who knows all the little porting tricks and such.
Reply #18May 28, 2013, 10:07:43 pm
Re: Boost response?
« Reply #18 on: May 28, 2013, 10:07:43 pm »
you dont need a ported turbo..
Reply #19May 29, 2013, 04:48:42 am
Re: Boost response?
« Reply #19 on: May 29, 2013, 04:48:42 am »
yeah u can clean up the inlets and outlets of the turbo for better transitions and clean up the castings some so everything is smoother, but i don't think there is that much to gain, the over all flow is really determined by the size of the compressor wheel and the a/r of the exhaust housing.  never ever ever port any of the areas that fits against the compressor or turbine wheel tho.
Reply #20May 29, 2013, 06:27:56 am
jaed_43725
Re: Boost response?
« Reply #20 on: May 29, 2013, 06:27:56 am »
Good to know. Is there a slightly smaller turbo that will bolt in place? I am only going to top off at 20 psi after I get an IC, and since this one is capable of so much more then I smaller one will do what I need, which is I need more boost at mid-range.
Reply #21May 29, 2013, 06:42:01 am
Re: Boost response?
« Reply #21 on: May 29, 2013, 06:42:01 am »
The only really "bolt on" alternative to the K24/T3 is a K14.  They are a good turbo and will definitely give you more midrange boost though they are not super common.  They can be found on some AAZ cars in Canada / Europe and on GTD 1.6 cars sold in Europe.  ~18 PSI is the upper range for a K14.
Reply #22May 29, 2013, 07:46:07 pm
jaed_43725
Re: Boost response?
« Reply #22 on: May 29, 2013, 07:46:07 pm »
Well I will be looking for a K14 then. Thank you.
Reply #23May 30, 2013, 04:33:30 pm
Re: Boost response?
« Reply #23 on: May 30, 2013, 04:33:30 pm »
VNT swap is pretty amazing as well, when set up correctly..
Reply #24May 30, 2013, 06:33:22 pm
Re: Re: Re: Boost response?
« Reply #24 on: May 30, 2013, 06:33:22 pm »
What he said... VNTs are the bee's knees. Not a "bolt on" replacement as you need to fabricate something to control the vanes but it's the best overall solution if you are prepared to do the work.
Sent from my HTC One X using Tapatalk 2
Reply #25May 30, 2013, 06:57:05 pm
jaed_43725
Re: Boost response?
« Reply #25 on: May 30, 2013, 06:57:05 pm »
I had an 02 Jetta TDI and the VNT was pretty awesome. But the crap you gotta do to make it work is so not worth it to me. I could only wish there was a bolt on super charger kit for these things.
Reply #26May 30, 2013, 07:27:09 pm
Re: Boost response?
« Reply #26 on: May 30, 2013, 07:27:09 pm »
turbo is better than s/c on a diesel..
Reply #27May 31, 2013, 05:43:11 am
Re: Boost response?
« Reply #27 on: May 31, 2013, 05:43:11 am »
i don't like superchargers as much, imo u don't get the boost as soon with a sc, the only time a sc gives u boost sooner is say a supercharged car and a turboed car are both cruising at 45 in 5th gear and they both throw it into second gear at the same time, the supercharged car will have the boost sooner.  but if they both stayed in 5th and floored it the turbo car would have boost sooner since its free spooling.  i've driven alot of super charged and turbo cars, they're both great but turbo is way better imo.  sc u never get full boost until the upper rpms, and thats just how it is because they can only spin the speed the engine allows.
Reply #28May 31, 2013, 12:57:10 pm
Gizmoman
  • 1301
Re: Boost response?
« Reply #28 on: May 31, 2013, 12:57:10 pm »
He's someone wanting to trade a K24 for a K14. At least I thinks that's the discussion.
http://www.vwdiesel.net/forum/index.php?topic=33466.0
Reply #29June 03, 2013, 05:13:02 pm
jaed_43725
Re: Boost response?
« Reply #29 on: June 03, 2013, 05:13:02 pm »
That is my post. I am gonna make the move and hope it works for the best.
