Author Topic: Out of fuel & glow plugs  (Read 19412 times)
Reply #30May 22, 2013, 02:47:40 pm
Kazuki
  • 61
Re: Out of fuel & glow plugs
« Reply #30 on: May 22, 2013, 02:47:40 pm »
If you got both lines in a can, and lets assume u got compression and glow, and the timing didnt jump,and the fuel solenoid is workin , id start lookin for a pump im thinkin.
Guys he said his aneroid pin is straight so it doesn't have boost enrichment anyways so IMO screw it and use a NA pump. Easier and cheaper to find
well im still looking for a pump anyone have one for sale?
Reply #31May 22, 2013, 03:07:40 pm
hillfolk'r
  • 1532
« Reply #31 on: May 22, 2013, 03:07:40 pm »
Throttle cables ftw
Reply #32May 22, 2013, 04:10:00 pm
Kazuki
  • 61
« Reply #32 on: May 22, 2013, 04:10:00 pm »
ok here the picture ignore the white marks look at the bottom around 5 oclock and you can see a notch in the gear not look at the mark on the plate uptop they dont line up but if you rotate 180 so that the socket is in the other hole then they will line up . unless im crazy .... ???
its hard to see the notch but you can see it if you look
btw if you click on the picture you can zoom it
Uploaded with ImageShack.us
Reply #33May 22, 2013, 04:55:35 pm
« Reply #33 on: May 22, 2013, 04:55:35 pm »
Is the flywheel mark @ TDC? If so, the IP would be 180o out.  (I would check the camshaft too.)
How badly did it run when it ran?
Reply #34May 22, 2013, 04:58:19 pm
Kazuki
  • 61
« Reply #34 on: May 22, 2013, 04:58:19 pm »
Yes tdc and I checked the cam she's good it ran OK but like poop sometimes
Reply #35May 22, 2013, 05:05:48 pm
EcoTX
  • 113
« Reply #35 on: May 22, 2013, 05:05:48 pm »
Looks like you have what I call the "bull*** pulley" that has two holes cut the same size on both ends and makes it easy to mess up if you aren't paying attention to the other mark.
Silly Germans, thanks for finally making it easier for us though!
Reply #36May 22, 2013, 05:28:53 pm
hillfolk'r
  • 1532
« Reply #36 on: May 22, 2013, 05:28:53 pm »
Hey when your timing is correct and if you pulled the nut off the ip pulley sprocket,the keyway notch should be at the 1 o'clock position. Can someone help me out here i forgot the exact position the keyway should be but i know it would definately be pointing towards the up position
Throttle cables ftw
Reply #37May 22, 2013, 05:50:33 pm
EcoTX
  • 113
« Reply #37 on: May 22, 2013, 05:50:33 pm »
The pulley's keyway is oriented like this to the correct hole you are supposed to use.
This keyway would actually be pointing towards around 9PM on a clock with the sprocket locked in correct position.
Timing the pump (moving the pump, not the sprocket) shouldn't affect the location of the keyway since it is locked in place.
*Hotlinked from one of the Prothe clones*
« Last Edit: May 22, 2013, 05:54:48 pm by EcoTX »
Reply #38May 22, 2013, 07:40:57 pm
« Reply #38 on: May 22, 2013, 07:40:57 pm »
Yeah if the cam is at tdc then the pump is 180 out
Reply #39May 22, 2013, 08:22:26 pm
Kazuki
  • 61
« Reply #39 on: May 22, 2013, 08:22:26 pm »
Hmm yeah I wonder how that happend maybe the shop didn't time it right ? It it jumped?
Reply #40May 22, 2013, 08:41:37 pm
hillfolk'r
  • 1532
« Reply #40 on: May 22, 2013, 08:41:37 pm »
Thats what i was lookin for, 9oclock :)
Throttle cables ftw
Reply #41May 23, 2013, 02:07:54 am
« Reply #41 on: May 23, 2013, 02:07:54 am »
This pulley gets to bone you if the internals of your pump are 180 off.
Reply #42May 23, 2013, 04:47:18 am
« Reply #42 on: May 23, 2013, 04:47:18 am »
if its that far out the shop screwed it up
Reply #43May 23, 2013, 09:15:09 am
Kazuki
  • 61
« Reply #43 on: May 23, 2013, 09:15:09 am »
ok so heres what i found  ???
Reply #44May 23, 2013, 09:26:07 am
EcoTX
  • 113
« Reply #44 on: May 23, 2013, 09:26:07 am »
Looks to be on there right, but does your sprocket not have the mark to line up with the mount mark?
I thought they all did regardless of year, that's strange.
