Author Topic: Am I a Dip stick ?  (Read 3635 times)
May 17, 2013, 08:46:52 am
Kazuki
  • 61
Am I a Dip stick ?
« on: May 17, 2013, 08:46:52 am »
am i missing something im pretty sure this isnt normal. is the bushing hold everything tight
? cause thats a lot of slop
Uploaded with ImageShack.us
« Last Edit: May 17, 2013, 11:13:17 am by Kazuki »
Reply #1May 17, 2013, 12:40:03 pm
Gizmoman
  • 1301
Re: Am I a Dip stick ?
« Reply #1 on: May 17, 2013, 12:40:03 pm »
There's a chance someone with more experience can tell what this is a picture of but I have no idea. From the title I'd guess it's a dipstick.
Either way whatever it is, it's obviously not a good fit. If it's a dipstick, I'd say it needs an o-ring or something is missing.
Reply #2May 17, 2013, 12:53:19 pm
wolf_walker
  • 1205
« Reply #2 on: May 17, 2013, 12:53:19 pm »
There is an 0-ring, that I went through the trouble of ordering the correct one for from VW, and it still leaked.
I ended up with High Torque silicone, regular RTV didn't last, to make the last one I had out quit leaking.
And it is kinda hard to tell how far in is correct, especially if the stick or brace had been bent before.
This is bothersome because it effects the reading on the dipstick.
I double checked mine afterwards by draining and adding a proper amount
of oil and noting the position on the stick.
If yours is bent at all, and you have the option, go find one that isn't bent, and
the fattest o-ring you can find that will slide in there to the stop, and seal it with
that High Torque gray silicone and you'll be done with it.
Mentat Text Two
Reply #3May 17, 2013, 01:34:48 pm
hillfolk'r
  • 1532
« Reply #3 on: May 17, 2013, 01:34:48 pm »
Pretty much what he said :)
Hey i seen this somewhere i think it was AZ? Lol.
Throttle cables ftw
Reply #4May 17, 2013, 02:23:20 pm
Kazuki
  • 61
« Reply #4 on: May 17, 2013, 02:23:20 pm »
OK so I just got some rubber o-rings and a copper washer she fits sung so I got some grey rtv and going to let her sit for 24 hrs
[/URL]
Uploaded with ImageShack.us[/img]
« Last Edit: May 17, 2013, 02:34:01 pm by Kazuki »
Reply #5May 17, 2013, 03:28:23 pm
JamesT
  • 151
« Reply #5 on: May 17, 2013, 03:28:23 pm »
You are a dipstick, that looks terrible.
I would say you're trying to put a 1.6 dipstick into a 1.9. I just eyeballed it, and the 1.6 is about an 8mm and the 1.9 is about 10mm. No way that'll seal.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #6May 17, 2013, 03:37:53 pm
Kazuki
  • 61
« Reply #6 on: May 17, 2013, 03:37:53 pm »
ah but its a 1,6 block so .... will a 1,9 gas one work?
Reply #7May 17, 2013, 04:06:47 pm
Gizmoman
  • 1301
« Reply #7 on: May 17, 2013, 04:06:47 pm »
hahahaha.
Seriously, isn't there supposed to be a tube of some sort sticking out of the block a bit? I had a long steel tube on the AAZ engine I'm installing in my Vanagon. As my application uses a filler tube that goes to the bottom of the 50 degree pan (with an intrregal dipstick in the cap), the stock tube isn't needed so I cut it off, tapped it and screwed in a bolt with red lock-tite on it.
I'm not familiar with 1.6's but me thinks there's something missing here.
I'd find a piece of tube (even copper) and force fit it into the hole, then slide the dipstick through that with an o-ring on it.
Reply #8May 17, 2013, 04:41:25 pm
Kazuki
  • 61
« Reply #8 on: May 17, 2013, 04:41:25 pm »
hahahaha.
^ i dont know why i dident think if that ... going to try that
Reply #9May 17, 2013, 06:19:31 pm
wolf_walker
  • 1205
Re: Re: Am I a Dip stick ?
« Reply #9 on: May 17, 2013, 06:19:31 pm »
That's a later 1.6 setup, all there is. Early one had pressed in tube. If the oring is about right and the tube bracket is bolted down it'll work. Some other leak will cover the sealant soon. :)
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #10May 17, 2013, 07:13:40 pm
Gizmoman
  • 1301
« Reply #10 on: May 17, 2013, 07:13:40 pm »
. . . I'd find a piece of tube (even copper) and force fit it into the hole, then slide the dipstick through that with an o-ring on it.
If you do find a tube that fits clean the id good and stuff it in there. Then smear some goo on the stick near the top and stuff it in there. Leave it sit overnight. In the morning you'll have a seal and the stick should pull out and leave the custom made seal inside the tube.
Reply #11May 18, 2013, 08:51:29 am
Kazuki
  • 61
« Reply #11 on: May 18, 2013, 08:51:29 am »
Well so far no leaks will report back later  :- :P
Reply #12May 18, 2013, 11:09:33 am
damac
  • 531
« Reply #12 on: May 18, 2013, 11:09:33 am »
I used black stuff in that situation every time I put an engine back together.  If I clean it, goop it and set it and then leave it alone to setup they have all been fine.  Black stuff seems to setup nastier than regular rtv, I have used it on transfer cases, etc.
On another note I have been wondering if the turbo diesels dipstick that gets bolted to the ip bracket is supposed to stay inside the tube to read correctly, or should the tip be exposed?
I have a handfull of setups I got from existing cars and blindly put one back on my last block.  But I can't read the oil level after a fresh oil change?  My tip is not exposed and most of my setups have real long tubes.  One of them has the tip being exposed.
1985 turbo diesel jetta
Reply #13May 18, 2013, 11:36:31 am
« Reply #13 on: May 18, 2013, 11:36:31 am »
Just the tip.
Reply #14May 19, 2013, 10:19:10 am
hillfolk'r
  • 1532
« Reply #14 on: May 19, 2013, 10:19:10 am »
Just the tip.
Thats what i told her last night. :)
That car is an 85, so it has the (lets say) a mk1 style tube with bracket. Can a later tube be put in like from my 91? Its the pressed in deal. But for now hey it may be ugly but its workin.
I prefer the gray silicone for the oil related things.
Throttle cables ftw
