Author Topic: Turbo setups! Need some info!  (Read 2364 times)
May 11, 2013, 01:46:01 pm
GTFORZA
  • 29
« on: May 11, 2013, 01:46:01 pm »
I've got a 1.6 TD. Looking for more power and better spool. I'm going to make my own T3 manifold with a divided flange. Aka twin scroll. The twin scroll with the proper turbo sizing should assist with turbo lag. also I will be using a quick spool flange. Of course pump modding and what not will be done. I just wanna find a small T3 twin scroll flanged turbo. Smallest on from is a giant Garrett gt32. Way to big without doing a 1.9 swap! Any ideas on a small t3 twin scroll turbo?
Reply #1May 11, 2013, 05:58:40 pm
Re: Turbo setups! Need some info!
« Reply #1 on: May 11, 2013, 05:58:40 pm »
Might want to look into what the Subaru guys  use they are all about split scroll for some reason.  I think the smallest t3 split scroll is .78. Which if ur using a quick spool valve will probably be ok.  I think ud be better off with a gt2056 or holder he221w tho rather than an old hard to find exhaust housing
Reply #2May 12, 2013, 02:28:36 am
GTFORZA
  • 29
« Reply #2 on: May 12, 2013, 02:28:36 am »
I did some flow research and that would be better suited for a early 90's 1.9 TD build I found the garrett 2259 with an internal wastegate. Not to shabby. Should go well with some intake manifold massaging, and me welding up a manifold. So does my turbo have a t3 flange?
Reply #3May 12, 2013, 09:50:41 am
GTFORZA
  • 29
« Reply #3 on: May 12, 2013, 09:50:41 am »
Nevermind I found out the the turbo flange for the TD is specific for the car.
