Author Topic: Electrical Issue, where to start...  (Read 4100 times)
May 01, 2013, 03:04:17 pm
pvc4life
  • 14
« on: May 01, 2013, 03:04:17 pm »
Driving around the 86 TD a few days ago and when turning on the AC I lost all electrical power in the car (no turn signals, lights, radio, fan, etc.). It stayed this way for a bit then came back, then off again later when trying to do anything such as turn on the headlights, fan etc. Cycling the key on and off didn't do anything to fix it.
Any suggestions on where to start other than looking at relays? Any specific relays to check out?
Thanks!
Reply #1May 01, 2013, 08:03:32 pm
Re: Electrical Issue, where to start...
« Reply #1 on: May 01, 2013, 08:03:32 pm »
I'd put the ventilation control in the heat position so the AC system is not active before starting, then check the voltage at the battery while running.
If good voltage (~13.5V - 14.2V) at battery while running, alternator is still ok.
With engine off, I'd remove the relay(s? ) mounted on the fan shroud and see if the problem persists. Don't run the engine very long for the test, as removing the relay may interrupt the supply to the radiator fan.
Did the AC actually work in recent memory?
Reply #2May 02, 2013, 12:18:51 am
« Reply #2 on: May 02, 2013, 12:18:51 am »
see if there is a loose wire going into your battery.
Reply #3May 02, 2013, 09:32:10 pm
  • 2926
« Reply #3 on: May 02, 2013, 09:32:10 pm »
Does the x relay run all of that stuff?
Reply #4May 03, 2013, 07:18:46 am
  • 1739
« Reply #4 on: May 03, 2013, 07:18:46 am »
I would look at the X [or 75] relay and the electrical part of the ignition switch
Reply #5May 03, 2013, 07:56:40 am
wolf_walker
  • 1205
Re: Re: Electrical Issue, where to start...
« Reply #5 on: May 03, 2013, 07:56:40 am »
Dodgy battery terminal connection can do that, bad grounds too. Check basics first.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #6May 03, 2013, 08:45:27 am
pvc4life
  • 14
« Reply #6 on: May 03, 2013, 08:45:27 am »
I will check that relay this weekend. Battery had a good ground and battery and alternator checked out fine.
