Author Topic: AHU TDI Doka  (Read 3105 times)
April 24, 2013, 06:54:52 pm
strawhouse
  • 7
AHU TDI Doka
« on: April 24, 2013, 06:54:52 pm »
Need some input on a TDI swap in my 1988 Doka.  I am trying to figure out what flywheel / pressure plate / clutch combo I need for hooking this thing up.  The Doka is originally diesel, it came with the 1.6TD.  I am thinking that I would use the AHU flywheel and pressure plate but use the 1.6TD style clutch...  this is just what I have read up to this point.  What are your thoughts?
Reply #1April 24, 2013, 08:06:46 pm
Re: AHU TDI Doka
« Reply #1 on: April 24, 2013, 08:06:46 pm »
no.. reuse stock parts... not same as tdi stuff.. but your stock stuff fits tdi
Reply #2April 24, 2013, 08:39:34 pm
Re: AHU TDI Doka
« Reply #2 on: April 24, 2013, 08:39:34 pm »
Use the TDI pressure plate and flywheel and the waterboxer 228mm disc.  You need to modify the nose of the starter, bend down the PP tabs and sometimes clearance a little in the bell housing.  Read up...
AAZ would be the same:
 http://www.vwdiesel.net/forum/index.php?topic=33157.0
