Author Topic: Guess what's wrong with my motor..  (Read 4921 times)
Reply #15April 30, 2013, 07:48:32 pm
Re: Guess what's wrong with my motor (mods move to IDI section pls.)
« Reply #15 on: April 30, 2013, 07:48:32 pm »
High pressure in #1 carbon or valve related.  Low in #2 is trouble as not very balanced across all 4.  Perhaps a bad seat on head for either or both valves.  Otherwise the 480 is spec on new motor.  Gain likely due to oiled rings the second time?
Reply #16June 14, 2013, 11:00:45 pm
masterbeavis
  • 88
Re: Guess what's wrong with my motor..
« Reply #16 on: June 14, 2013, 11:00:45 pm »
Update:
I reran compression. I allowed 5 revolutions on a cold motor.
450
380
420
440
Before putting it back together I cranked the motor for a while to see how the lifters pump up. 3 are weak, over 1/8" deflection.  I put it back together as-is, still had the knock. This time I cracked injector lines once running to isolate the offending cylinder, put in another injector, the noise went away!  It does not run right however. It's low end torque is gone, you can feel the misfire. I need my injectors gone through and lifters.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #17June 15, 2013, 06:14:04 am
« Reply #17 on: June 15, 2013, 06:14:04 am »
A stuck injector sounds just like a rod knock.
Compression test should be done on a warmed up engine and the number of revolutions DOES NOT MATTER.  You should keep spinning the engine for a given cylinder until the pressure no longer rises on the gauge.  That's usually a heck of a lot more than 5 revs.
« Last Edit: June 15, 2013, 06:15:39 am by libbydiesel »
Reply #18June 15, 2013, 07:26:22 am
masterbeavis
  • 88
« Reply #18 on: June 15, 2013, 07:26:22 am »
I've ran the compression test 3 times on this motor, twice cranking till the end of time and getting the first two set of numbers. I'm not going to warm a car up with a suspected spun bearing to do a compression test. If I was doing the test wrong, the numbers cold are still high enough to convince me the motor was worth fixing.
Reply #19June 15, 2013, 09:58:18 am
« Reply #19 on: June 15, 2013, 09:58:18 am »
He is not telling you to run the engine to operating temps, just merely that a proper compression test is done warm is all.
Reply #20June 15, 2013, 09:35:21 pm
masterbeavis
  • 88
« Reply #20 on: June 15, 2013, 09:35:21 pm »
Will a warm motor give better or worse results?
Reply #21June 15, 2013, 09:50:34 pm
« Reply #21 on: June 15, 2013, 09:50:34 pm »
I believe that warm is better results as expansion of all parts means higher numbers.  Cold is leaky.
