Author Topic: So this happened (ac compressor content)  (Read 5819 times)
April 23, 2013, 04:59:37 pm
jboogie13
  • 175
« on: April 23, 2013, 04:59:37 pm »
My issue is the broken tab on the AC compressor that locks the belt tensions
Ive been having issues with my alternator/belt and i just replaced my alternator only to find this tab broken...i think i know why my belt slips!  ::)
I'm thinking of having a welding shop weld a tab back on just so i can hold tension as the AC system doesnt work anyways but i would like to keep it installed for a future owner who desired to fix it. Unless someone has a Compressor they would be willing too hook me up with?  i have a few IP's than can be used as cores for trade and some other misc parts. any help is appreciated!
I should mention that this is on a 1991 ECO diesel
« Last Edit: April 24, 2013, 05:15:28 am by jboogie13 »
Reply #1April 23, 2013, 06:11:04 pm
Re: Re: So this happened (ac compressor content)
« Reply #1 on: April 23, 2013, 06:11:04 pm »
I seem to recall that the compressor has 4 mounting tabs and can be rotated around to the next good one in such a situation... No need to have it welded.
Sent from my HTC One X using Tapatalk 2
Reply #2April 23, 2013, 06:26:08 pm
jboogie13
  • 175
« Reply #2 on: April 23, 2013, 06:26:08 pm »
I never thought of that! can anybody confirm? I will be taking a look tomorrow. Thanks so much for the info.
« Last Edit: April 23, 2013, 06:29:06 pm by jboogie13 »
Reply #3April 24, 2013, 01:02:56 am
bbob203
  • 1789
« Reply #3 on: April 24, 2013, 01:02:56 am »
can't be rotated tabs are specific location. just scraped an ac compressor  :-[
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4April 24, 2013, 05:01:57 am
jboogie13
  • 175
« Reply #4 on: April 24, 2013, 05:01:57 am »
any input on getting it welded?
Reply #5April 24, 2013, 05:47:52 am
92EcoDiesel Jetta
« Reply #5 on: April 24, 2013, 05:47:52 am »
I have a compressor (deleted ac) from my Eco if you need one.
« Last Edit: April 24, 2013, 05:50:09 am by 92EcoDiesel Jetta »
Reply #6April 24, 2013, 06:04:16 am
jboogie13
  • 175
« Reply #6 on: April 24, 2013, 06:04:16 am »
ok, i will contact you shortly, i have read an even mix of people saying it is rotate-able and some saying it's not. i will be taking a look today.
Reply #7April 24, 2013, 06:33:22 am
« Reply #7 on: April 24, 2013, 06:33:22 am »
tabs pretty much same.. but line fittings/clutch wire.. no so simple to move...
Reply #8April 24, 2013, 06:55:33 am
jboogie13
  • 175
« Reply #8 on: April 24, 2013, 06:55:33 am »
i would rather extend a wire and cap some refrigerant lines than pay for a new compressor haha,
Reply #9April 25, 2013, 05:00:42 am
jboogie13
  • 175
« Reply #9 on: April 25, 2013, 05:00:42 am »
good news! I was sucessful in indexing the compressor 90 degrees, and everything bolted up great. since my system was empty already, i just had to crack the b-nuts on the lines to the compressor before i rotated it, then tightened the down once it was installed again. Re-routed the clutch wire and everything worked out. thanks for all the help everyone!
