Author Topic: starting to get used to it(power),more of a ve pump question  (Read 4217 times)
March 06, 2006, 08:55:33 pm
hillfolk'r
  • 1532
« on: March 06, 2006, 08:55:33 pm »
its runnin great, the tdi-m,ive almost killed the front tires already,and iaint tryin to either, its got about 1200 miles on it or so,,,,i wanna do the intermediate gov spring mod,,but first,,,ive been turnin the max fuel in,tunin' er up,,,and im at the point where the lockcollar will need to be removed,yea its still on there,,,,12mm head remember,,,,,but my idle screw is almost all the way out,,like the throttle lever  almost rests against the idle screw stop casting,   ,it seems like "1/2 turn in onfuel,backidle out about 2 turns,approx"rev up to see if it hangs,,if it does back idle downmore,,,,wellim out of idle screw,,,question is,,can i move the throttle lever on the pump 1 spline,,so icankeep turning in the fuel,,and regain some of the idle screw threads??ihavent seen it go over 1200pre turbo,
Throttle cables ftw
Reply #1March 08, 2006, 09:29:56 pm
hillfolk'r
  • 1532
« Reply #1 on: March 08, 2006, 09:29:56 pm »
anyone of the pump guys around??hmmm..must all be in the garage wrenchin on the rides, :(
Throttle cables ftw
